Thanks for bringing attention to Debian, although I wouldnât classify it as troubling per se, what you are seeing here is the normal Debian processes at work. Let me preface this with that I have been using Debian exclusively for more than ten years.
Debian is a community based distro, it doesnât have any major corporation backing it and controlling the direction that it goes, it is a mostly a group of unpaid volunteers that do all of the work.
The typical Debian user doesnât crave new software just for the sake of it being new, someone who does would be better served by using a different distro.
The entire reason that you are not seeing any chatter on Debian, is because for them this is the normal state of affairs, which is roughly this for both Firefox-esr and Thunderbird.
- A new version drops from Mozilla.
- They update all of underlying dependencies that needs to be updated first (rust compiler, etc).
- They compile the new version for stableâs security repo.
- Once that is released then they they back-port to all of the other releases that are still active, old stable, old old stable, etc.
- By the way, they are doing this for all of the architectures, ten if I counted correctly.
All of those steps take time to implement, is it perfect, no, but I am quite surprised at how well it works overall.
So once the above steps have been completed, plus thanks to Firefoxâs constant stream of security issues, Debian will have the latest Firefox-esr and Thunderbird in the security repoâs for all of the active releases, which is pretty decent in my book.
As a Debian user and advocate myself I found it a little bit concerning to be honest.
I agree with most of the above comments about how Debian works but a browser is essential and it is a security hole in the operating system to use an outdated version of Firefox! I would even say it is unacceptable.
The state of browsers in Debian is very poor in general. Look at the Chromium package. The project itself discourages its use but still packages it. I will not mention all the other browsers. But you should not use them.
In the last release they needed months and months to offer a recent and patched version of Chromium.
In my opinion there is no excuse for that regardless how the packaging works. I am not sure if there is not enough manpower or the project just fails with the whole amount of packages they offer, one of the largest repos in the Linux ecosystem if not the largest of any.
So it is good to be aware of that.
I wonder what the underlying reason is that the Debian project couldnât move the browser portion more quickly? Do you think it is due to dependencies? If I were running Debian, I would probably use Flatpak or Snaps as a stop-gap, especially since this does become a security concern.
So I totally did not know about the extensions available for standard notes and now am really happy to find them. I was using simple notes but found out they were not encrypted in any way, so I was looking for something a little more private as well as open source, so my two options seemed to be simple note and Joplin. I first tried standard notes and was really not that impressed because I couldnât do the simple thing of adding check boxes for grocery list and stuff. So then I tried Joplin next, it has a really awesome desktop app, and you can use your own cloud services to sync it between devices(like Nextcloud and some others) but the mobile app stinks, so I wasnât happy with it either but stuck with it because of how awesome the desktop app is. Now while watching this show I started playing with the standard note extensions, and I am now much, much happier with it and am now switching back to it.
a better question is why does firefox not build on bullseye, which isnât all that old. for mesa? a graphics acceleration library? maybe mozilla can take a look at their build requirements.
flatpak and snaps add a messy layer of abstraction and it just kicks the security can down the road to whomeverâs maintaining it. At least with traditional packaging maintainers are forced to keep up with new libraries (that often improve security) but with containers you can just party like itâs 1999 forever. It feels like replacing one problem with another.
Something Debian (or any Debian user) can implement right now is packaging the sid or testing versions of their favorite browser as an AppImage and installing it in /usr/local/bin. It keeps maintainership/packages within the Debian family and itâs pretty seamless compared to flatsnaps.
Using flatpaks or snaps is against Debianâs strict policy of maintaining packages by its official maintainers and I agree here.
They should just open the gates for newer packages faster when it is needed like in this case, even if it is because of Mesa or Rust, but they are just too conservative about that because the policy only allows patches and security updates and âby no meansâ any new package to go into stableâs repository. Here you can already see the problem regarding Chromium.
Though sometimes you have to make an exception I would say instead of discussing the problem endlessly why something cannot be packaged.
Now I am not really sure if the missing libraries can be back-ported even to the same version of Mesa or Rust, my point is that I see it as an ideologically issue rather than a technical.
I think a good Christmas geek gadget would be pretty much anything Raspberry Pi (which isnât already sold out). Or decent-quality accessories (known to be compatible) to go with such boards.
I recently got a CM4 in a small router appliance that Iâm quite happy with. I must admit those CM4 boards are really cute and small, when you see them in real life.
- Debian Stable is currently on Firefox ESR 78.15 released 2021-10-05
- Version 91.x came out 2021-10-28 and has had 2 releases so far
Mozilla release calendar: https://wiki.mozilla.org/Release_Management/Calendar
According to this Mozilla doc, thereâs â(at least 12 weeks) overlap between the time of a new release and the end-of-life of the previous releaseâ
So while Mozilla wonât consider Debianâs ESR EOL until ~Jan 05, itâs a pretty major leap behind the current ESR.
Thereâs also this: âMaintenance of each ESR through point releases is limited to high-risk/high-impact security vulnerabilitiesâ so lagging point releases is lagging behind high-risk/high-impact security vulnerabilities.
As for Chromium⌠their download page states:
âGoogle does not offer old builds as they do not have up-to-date security fixes.â
The Debian Stable version is 90.0.4430.212 which was released May 8th, 2021 and thereâs been several releases since then.
Worth noting⌠ungoogled-chromium is also version 90.0.4430.212.
The Chromium Docs - Chrome Release Cycle gets a bit above my head but iâm reading the dev builds as having no more releases after 6 weeks whichâd put the Debian version several months behind on support.
Just to emphasize on this, here is Debianâs own recommendation:
https://wiki.debian.org/Chromium#Installation
As of 2021-10-14 19:19:07, Debianâs Chromium package in buster, bullseye and bookworm repository remains vulnerable to numerous CVEs as outlined in the Chromium Security Tracker. Consider using an alternative browser like Firefox, Brave or ungoogled-chromium.
Edit: As of now Firefox ESR 78.15, regardless of its lifespan, is vulnerable in all Debian branches except sid and testing.
https://security-tracker.debian.org/tracker/source-package/firefox-esr
I had question on the Yubikey is there a specific model that is best? That tech is relatively new to me and I collect all things techy. So I would like to know more from your prospective.
Thank you.
FYI, Debian just upgraded to 11.2 point release which upgrades Firefox ESR to 91.4.1.
As a Debian guy here I just wanted to give the perspective that Debianâs release schedule is famously slow and only until relatively recently have we started having multiple released of browsers per month, let alone in a year.
Does no one else remember how FF changed its naming scheme to follow Chromiumâs inflated build numbers? Basically, after v38 everything exploded, and we would have multiple versions released per a year. It is a fast moving target, and you have to wonder how anyone who packages it for as many architectures as Debian ever gets it done.
Thanks, everyone! Some great ideas for pressies from back in the festive season for many ![]()
Sorry Iâm so far behind on podcasts, but just my reflections on browser updates, particularly with Debian Stable, as itâs been my workhorse for 8-9 years now, canât even remember(!)
As far as I know Firefox ESR (default browser under Debian Stable) tracks normal Firefox but then âfreezesâ in a sense for several months during which only security updates are backported, not feature updates. I think this works fine for organisations, especially given that even a few years back feature updates on browsers sometimes broke things, though thatâs not heard about much these days. Every several months or-so, Firefox ESR gets a large jump in version numbers when it moves forward several months on the normal Firefox numbering, so although numbering can look âvery behindâ thatâs actually by design, and Debian inherits the same.
The issue of timely updates to browsers, especially nowadays with financial transactions, especially, is of course crucial, I agree; and they, like all security updates, really should be implemented as fast as possible. I generally find security updates on Debian Stable to be very fast. With the larger Firefox-ESR âjumpâ every few months, I am guessing because of the size of the job, there may well be a lag of some days, during which I definitely think use of Flatpak Firefox is preferable. That being said, once the normal repo FIrefox-ESR has reached the same latest version-point, I trust its security more than Flatpak.
I think an important question is, besides the browser, are other security problems with underlying libraries slow to fix on Debian too? Iâve never noticed this myself, though reflections from community members would be very welcome of course ![]()
As a side-note, I also think that users of LibreWolf need to keep an eye on security patches, because although it tracks normal Firefox updates, there can sometimes be a lag of a day or so (I seem to notice) before updated LibreWolf builds become available.
It is true, Debian applies security updates quickly. They have a default repo called âsecurityâ just for that.
However, even with firefox-esr it does not pin to one version and upgrades point releases all the time. Here is my list over the last few months.
Preparing to unpack .../19-firefox-esr_78.9.0esr-1_amd64.deb ...
Leaving 'diversion of /usr/bin/firefox to /usr/bin/firefox.real by firefox-esr'
Unpacking firefox-esr (78.9.0esr-1) over (78.9.0esr-1~deb10u1) ...
Setting up firefox-esr (78.9.0esr-1) ...
Preparing to unpack .../1-firefox-esr_78.10.0esr-1~deb10u1_amd64.deb ...
Unpacking firefox-esr (78.10.0esr-1~deb10u1) over (78.9.0esr-1) ...
Setting up firefox-esr (78.10.0esr-1~deb10u1) ...
Preparing to unpack .../2-firefox-esr_78.10.0esr-1_amd64.deb ...
Unpacking firefox-esr (78.10.0esr-1) over (78.10.0esr-1~deb10u1) ...
Setting up firefox-esr (78.10.0esr-1) ...
Preparing to unpack .../042-firefox-esr_78.8.0esr-1_amd64.deb ...
Unpacking firefox-esr (78.8.0esr-1) over (78.8.0esr-1~deb10u1) ...
Setting up firefox-esr (78.8.0esr-1) ...
Preparing to unpack .../01-firefox-esr_78.9.0esr-1~deb10u1_amd64.deb ...
Unpacking firefox-esr (78.9.0esr-1~deb10u1) over (78.8.0esr-1) ...
Setting up firefox-esr (78.9.0esr-1~deb10u1) ...
Selecting previously unselected package firefox-esr.
Preparing to unpack .../0428-firefox-esr_78.7.0esr-1~deb10u1_amd64.deb ...
Adding 'diversion of /usr/bin/firefox to /usr/bin/firefox.real by firefox-esr'
Unpacking firefox-esr (78.7.0esr-1~deb10u1) ...
Setting up firefox-esr (78.7.0esr-1~deb10u1) ...
update-alternatives: using /usr/bin/firefox-esr to provide /usr/bin/x-www-browser (x-www-browser) in auto mode
update-alternatives: using /usr/bin/firefox-esr to provide /usr/bin/gnome-www-browser (gnome-www-browser) in auto mode
Preparing to unpack .../02-firefox-esr_78.7.0esr-1_amd64.deb ...
Unpacking firefox-esr (78.7.0esr-1) over (78.7.0esr-1~deb10u1) ...
Setting up firefox-esr (78.7.0esr-1) ...
Preparing to unpack .../04-firefox-esr_78.8.0esr-1~deb10u1_amd64.deb ...
Unpacking firefox-esr (78.8.0esr-1~deb10u1) over (78.7.0esr-1) ...
Setting up firefox-esr (78.8.0esr-1~deb10u1) ...
Preparing to unpack .../042-firefox-esr_91.5.0esr-1_amd64.deb ...
Unpacking firefox-esr (91.5.0esr-1) over (91.4.0esr-1) ...
Setting up firefox-esr (91.5.0esr-1) ...
Preparing to unpack .../05-firefox-esr_91.4.0esr-1_amd64.deb ...
Unpacking firefox-esr (91.4.0esr-1) over (78.15.0esr-1~deb10u1) ...
Setting up firefox-esr (91.4.0esr-1) ...
So while firefox-esr is not the âlatest versionâ it does release versions with security updates. This is explained on Mozillaâs versions page. To quote:
Extended Support Release (ESR) receives major updates on average every 42 weeks with minor updates such as crash fixes, security fixes and policy updates as needed, but at least every four weeks.
The problem wasnât the regularity of security updates. It was how long it took from the point Mozilla released them to when theyâd show up on Debian Stable.
Sort of like shipping 2 people a package every 10 days but one person lives in the same city and the other lives internationally. Both would receive packages regularly but 1 person would have old contents.
I did a quick Debian Stable VM test w/ fresh install of Firefox-ESR just now and itâs running version 91.5.0 (latest ESR) which was released 2022-01-11 by Mozilla so if youâre running Firefox ESR on Stable today you have the latest ESR version and security from Mozilla.
When I last posted above it was Dec 21st, same test, the ESR version was 78.15.0 which was ~2 months beyond the point Mozilla dropped security for 78.x so if you were running Firefox ESR on Stable in Dec you were no longer supported whether you were getting security updates or not.
Firefox-ESR on Debian Stable today:
So with that huge improvement, well done Debian! Well done DL!
Indeed Firefox-ESR on Debian Stable does update very regularly. I wonder if perhaps it was at the âbig jumpâ a delay of a few days was (understandably) noticed by some users, prompting this concern. It was a few months ago now, so I guess my lag even on viewing the podcast is a little funny ![]()
Extra:
v91.6 is scheduled to release today which is the latest security update for Debianâs Firefox ESR (ESR point releases are the security updates). Itâll be interesting to see how soon it hits Stable.
Some house cleaningâŚ
Back when I posted this I made an estimate of 78.x support till Jan 05 but I got it a bit muddled, support ends 3 cycles after a new âwholeâ version upgrade so Firefox 78.x left security support 2021-10-05 despite Debian Stable still shipping it in 2021-12-17 when I posted.
Strictly comparing my screenshots, Debian Stable missed over 2 months worth of security updates and had 3 months prior to make the jump to 91.
