Heard y’all talk about checking out pihole on the ep 56. I highly recommend it.
I set it up on an old laptop running Ubuntu server 20.04 about a month ago. It’s a lot of fun blocking ads and reports home from all the different devices on my network.
You can grep the pihole logs and find domains that might not be on your ad-list. The only problem here is that unless you tell your hosts to use the Pihole as their DNS it is sometimes hard to parse those logs, everything is shown as your router making the request. And a lot of devices you can’t change their DNS server. Like a smart light, or vacuum. But if you have a router that lets you look at the DNS logs, one running OpenWRT, you can grep those logs (after you enable logging) for the specific IP of the devices. Then find out that the smart TV that Sony has dropped support for years ago is still sending analytics back to sony. Or your smart light is sending in usage data every time you turn it on or open the app.
PiHole was my first RPi project several years ago, right after attending a Linux meeting hosted by @dasgeek That was my introduction to Destination Linux.
PiHole is awesome. It’s very easy to use for internal DNS records.
+1 for this. I didn’t know it could do that and I had gotten tired of remembering all my IP addresses. Plus, I can get to jellyfin.family.lan now instead of 192.168.1.242:8098 or whatever the port is.
@anunarmedpawn: welcome! As for the DNS on PiHole, can’t you set it to be the DHCP server too (and disable DHCP from the router)? I haven’t tried this yet due to lack of time to take everyone off then network if something goes afoul, but it should then show all the traffic per device, instead of as the router as the only device.
Yes, that’s what I do. I’ve disabled DHCP on my router and switched it on the Pihole. All the reports have PC or device names now and are much more readable.
I don’t run DHCP from the PiHole as I don’t want the PiHole to become a single point of failure (yes, I understand that my router is a single point of failure).
I have my DHCP server assign the PiHole is the primary DNS server and I, personally, assign Quad-9’s public DNS as the secondary DNS. This way, if the PiHole experiences any type of outage no one is impacted (other than getting ads until the PiHole comes back online).
Yeah, looking back this probably was the better option. Now I’ve figured what I want to block for each device. I may have been a bit excited to play with a new router with open source firmware on it. It would be great to hear an episode on OpenWRT if there isn’t one already
cheers
I want one of the WRT routers, but don’t have one. I also want to change my PiHole to do DHCP too, I’ll add it to the summer project list… Enjoy using PiHole though!
I had a RP sitting in a closet for years, never knowing quite what to do with it. Then I saw an article about Pi-Hole and gave it a shot. It’s now become one of those can’t imagine life without it tools. The amount of useless chatter on a fairly small home network is almost insane. Tuning the block lists took a little time but it’s not difficult and so worth it. My favorite benefit is blocking most of the annoying ads in mobile apps. When I’m not home and without the filtering I am reminded of how awful some of those apps can be.
I’ve thought about the mobile space as well. I haven’t ventured into Wireguard, but I’ve seen DO tutorials for Wireguard setups with PiHole precisely for that.
Does your ISP allow for bridge mode on their provided router? If so, this would allow you to use your own router by configuring their device as a type of pass-through.
If you already have a home lab server (Linux), there is a cheaper way. PiHole can be run in a container or as a VM, so no additional hardware required other than the VM host or server running Docker.
