For those few that know me, I don’t do a lot tech-wise during the summer since I end up hanging out on the back deck with a cigar (or two) and an adult beverage almost every night. Winter however, is when the geek takes over to keep from being bored when I can’t be outside. With summer hopefully coming to an end (it was 101F here yesterday! It’s friggin’ OCTOBER!), I’m preparing my next project.
I currently have a half rack of used enterprise equipment in my basement and one component is a NAS with ~160TB of raw storage running FreeNAS. It’s absolutely fantastic and rock solid, but it’s in the basement while my home office is on the 2nd floor of the house. I haven’t ran ethernet between the two yet (long story) so I’m on wifi in the office & I/O to the NAS can be a fizzle frustrating at times with larger files. So, my solution to that problem & boredom prevention… another NAS in the office. Plus, I can have the two sync so I end up with another local copy of my files. Anyway…
I’ve been casually planning the build for a couple of weeks and came up with the following criteria:
- QUIET operation. There’s a small bathroom between my home office and bedroom so I don’t want a loud server in there like I have in the basement. Actually, it probably wouldn’t bother me, but it may put my wife over the edge with all my shenannigans and cause her to murder me in my sleep.
- Power efficient. With a half rack of enterprise servers in the basement already gulping power like a fat man gulping water after chasing an ice cream truck, the last thing I need is another power hungry server (see note about understanding wife above).
- Low(er) cost. So I’m not the best at sticking to a budget, I gave up on that years ago. Now, I just try to go cheap…keyword: “try”. With this in mind, even though I’m building from scratch & for me that usually means new hardware, I’m going to look at pre-owned first. Doesn’t pre-owned sound so much better than “used”?
- Unique build. So this is subjective I guess but it’s a challenge to myself to do something new, weird, funky, outside the box, whatever. After a lot of thought and browsing a bajillion threads online, I have an idea. It’s not unique in that it’s never been done (duh, someone else has already done it), but I’ve never done anything like it so it qualifies.
I’m still working through some of the components and setup but the first step has been taken, the motherboard. I found a pre-owned Super Micro X10SL7-F on eBay for $50. It’s small which will help me keep the space used in the office to a minimum while still giving me 8x drive connections and supporting ECC memory as well as a lot of other standard “server class” specs. Someone mentioned the VGA & only one expansion slot but I doubt I even have a monitor plugged in after the initial install. I also have some extra RAM thanks to the servers in the basement but no doubt I won’t be able to resist getting more & maxing the board out. (Narrarator: …and no one was surprised) I have a few extra processors from the servers downstairs that I think will fit but I’ll confirm. They’re older, but won’t be under any stress with the NAS anyway.
For now, I’m going to use a few drives I already have on hand but I will be getting more. No doubt they’ll be WD Reds but the size will depend on price so we’ll see how that goes. The only thing I’m still not 100% sure about is the power supply. Still working through that & open to suggestions.
What’s that you say? What about a case? Bwahahahaha! That’s the best part!! And you’re gonna have to wait! ![]()
I’ve meant to do write-ups about my network, setups, builds, etc… for a long time but just haven’t gotten around to it. In fact, it’s been so long that Michael has stopped asking about them, so you know it’s been a LONG time. My goal is to update this post and answer questions as I go. I’m also open to any & all comments or suggestions so feel free to reach out.
BC (AKA: Tech Santa)
