I might be blind, deaf or maybe both ![]()
I can’t figure out where we are going to meet up at the Megafest?
Are the stream/event on YouTube, Discord or Twitch?
Where do I meet up so i don’t miss out on the party?![]()
Just for you or anyone else interested:
Localized time: 2021-08-22T20:00:00Z
You’ll need Jitsi, download here: Download | Jitsi
Extremely easy to use but it’s recommended to get it installed and play with it a bit first. Test your mic, ect.
Link/room name should be posted on the Forum and/or Matrix Chat prior to the event.
We will be using Jitsi. The link to join us will be posted here on Discourse right before 3pm EST start.
I cannot get Jitsi to install!
I added the repo and sudo apt install jitsi-meet…after that it asked if i wanted to self-sign … then it errors saying system problem send report?
Jitsi also works in a web browser…I’ve been using it that way for DLN.
how? just go to a link??
Yes, after they’re done recording the live show (which you can watch right now at dlnlive.com or YouTube, in case you aren’t already), they’ll post a link for the Jitsi session. Just click on that and it should work in your browser.
thanks!
