What 3D printer do you have?
I’d love to get a 3D printer order in the next week or so. I’m thinking about getting this one:
However, I’d love to know:
  1. What do you use?
  2. What are the pros?
  3. What are the cons?
  4. Was it worth what you paid for it (build quality)
  5. Would you recommend it?
I use a Longer LK4.
Pros:
  • Easy to build (some of these 3D printers take hours to put together!)
  • Affordable
  • Works well with Octopi
  • Can print directly from SD Card no computer interface required
Cons:
  • Some software doesn’t list it as an official model so you have to manually add bed size, nozzle size, temps, etc.
Would definitely recommend it for a beginner 3D printer. There are better options but this one has served me well.
