Ubuntu 20.04 with btrfs-luks full disk encryption including /boot and auto-apt snapshots with Timeshift
Video
Note that this written guide is an updated version of the video and contains much more information.
Overview
Since a couple of months, I am exclusively using btrfs as my filesystem on all my systems, see: Why I (still) like btrfs. So, in this guide I will show how to install Ubuntu 20.04 with the following structure:
  • a btrfs-inside-luks partition for the root filesystem (including /boot) containing a subvolume @ for / and a subvolume @home for /home with only one passphrase prompt from GRUB
  • either an encrypted swap partition or a swapfile (I will show both)
  • an unencrypted EFI partition for the GRUB bootloader
  • automatic system snapshots and easy rollback similar to zsys using:
    • Timeshift which will regularly take (almost instant) snapshots of the system
    • timeshift-autosnap-apt which will automatically run Timeshift on any apt operation and also keep a backup of your EFI partition inside the snapshot
    • grub-btrfs which will automatically create GRUB entries for all your btrfs snapshots
  • If you need RAID1, follow this guide: Ubuntu 20.04 btrfs-luks-raid1
With this setup you basically get the same comfort of Ubuntu’s 20.04’s ZFS and zsys initiative, but with much more flexibility and comfort due to the awesome Timeshift program, which saved my bacon quite a few times. This setup works similarly well on other distributions, for which I also have installation guides with optional RAID1.
If you ever need to rollback your system, checkout Recovery and system rollback with Timeshift.
Step 0: General remarks
I strongly advise to try the following installation steps in a virtual machine first before doing anything like that on real hardware!
So, let’s spin up a virtual machine with 4 cores, 8 GB RAM, and a 64GB disk using e.g. the awesome bash script quickemu. I can confirm that the installation works equally well on my Dell XPS 13 9360, my Dell Precision 7520 and on my KVM server.
This tutorial is made with Ubuntu 20.04 Focal Fossa copied to an installation media (usually a USB Flash device but may be a DVD or the ISO file attached to a virtual machine hypervisor). Other versions of Ubuntu or distributions that use the Ubiquity installer (like Linux Mint) also work, see my other installation guides.
Step 1: Boot the install, check UEFI mode and open an interactive root shell
Since most modern PCs have UEFI, I will cover only the UEFI installation (see the References on how to deal with Legacy installs). So, boot the installation medium in UEFI mode, choose your language and click Try Ubuntu. Once the Live Desktop environment has started we need to use a Terminal shell command-line to issue a series of commands to prepare the target device before executing the installer itself. As I have a German Keyboard, I first go to Settings -- Region & Language and set my keyboard layout.
Then, open a terminal (CTRL+ALT+T) and run the following command:
mount | grep efivars
# efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
to detect whether we are in UEFI mode. Now switch to an interactive root session:
sudo -i
You might find maximizing the terminal window is helpful for working with the command-line. Do not close this terminal window during the whole installation process until we are finished with everything.
Step 2: Prepare partitions manually
Create partition table and layout
First find out the name of your drive. For me the installation target device is called vda:
lsblk
# NAME  MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
# loop0   7:0    0   1.9G  1 loop /rofs
# loop1   7:1    0  27.1M  1 loop /snap/snapd/7264
# loop2   7:2    0    55M  1 loop /snap/core18/1705
# loop3   7:3    0 240.8M  1 loop /snap/gnome-3-34-1804/24
# loop4   7:4    0  62.1M  1 loop /snap/gtk-common-themes/1506
# loop5   7:5    0  49.8M  1 loop /snap/snap-store/433
# sr0    11:0    1   2.5G  0 rom  /cdrom
# sr1    11:1    1  1024M  0 rom
# sr2    11:2    1  1024M  0 rom
# vda   252:0    0    64G  0 disk
You can also open gparted or have a look into the /dev folder to make sure what your hard drive is called. In most cases they are called sda for normal SSD and HDD, whereas for NVME storage the naming is nvme0. Also note that there are no partitions or data on my hard drive, you might want to double check which partition layout fits your use case, particularly if you dual-boot with other systems.
We’ll now create the following partition layout on vda:
  1. a 512 MiB FAT32 EFI partition for the GRUB bootloader
  2. a 4 GiB partition for encrypted swap use
  3. a luks1 encrypted partition which will be our root btrfs filesystem
Some remarks:
  • /boot will reside on the encrypted luks1 partition. The GRUB bootloader is able to decrypt luks1 at boot time. Alternatively, you could create an encrypted luks1 partition for /boot and a luks2 encrypted partition for the root filesystem.
  • With btrfs I do not need any other partitions for e.g. /home, as we will use subvolumes instead.
  • If you don’t want a swap partition, I will also show how to create a swapfile inside its own subvolume @swap below. Note, however, that if you plan to use RAID1 with btrfs, swapfiles are not supported, and you should stick to an encrypted swap partition.
Let’s use parted for this (feel free to use gparted accordingly):
parted /dev/vda
  mklabel gpt
  mkpart primary 1MiB 513MiB
  mkpart primary 513MiB 4609MiB
  mkpart primary 4609MiB 100%
  print
  # Model: Virtio Block Device (virtblk)
  # Disk /dev/vda: 68.7GB
  # Sector size (logical/physical): 512B/512B
  # Partition Table: gpt
  # Disk Flags:
  # Number  Start   End     Size    File system  Name     Flags
  #  1      1049kB  538MB   537MB                primary
  #  2      538MB   4833MB  4295MB               primary
  #  3      4833MB  68.7GB  63.9GB               primary
  quit
Do not set names or flags, as in my experience the Ubiquity installer has some problems with that.
Create luks1 partition and btrfs root filesystem
The default luks (Linux Unified Key Setup) format used by the cryptsetup tool has changed since the release of Ubuntu 18.04 Bionic. 18.04 used version 1 (“luks1”) but more recent Ubuntu releases default to version 2 (“luks2”) and check that /boot is not located inside an encrypted partition. GRUB is able to decrypt luks version 1 at boot time, but Ubiquity does not allow this by default. Note that if you want to use luks version 2 you should create an encrypted /boot partition using version 1, whereas the root filesystem can then be formatted using version 2. Either way, we need to prepare the luks1 partition or else GRUB will not be able to unlock the encrypted device. Note that most Linux distributions also default to version 1 if you do a full disk encryption (e.g. Manjaro Architect).
cryptsetup luksFormat --type=luks1 /dev/vda3
# WARNING!
# This will overwrite data on /dev/vda3 irrevocably.
# Are you sure? (Type uppercase yes): YES
# Enter passphrase for /dev/vda3:
# Verify passphrase:
Use a very good password here. Now map the encrypted partition to a device called cryptdata, which will be our root filesystem:
cryptsetup luksOpen /dev/vda3 cryptdata
ls /dev/mapper/
# control  cryptdata
We need to pre-format cryptdata because, in my experience, the Ubiquity installer messes something up and complains about devices with the same name being mounted twice.
mkfs.btrfs /dev/mapper/cryptdata
# btrfs-progs v5.4.1
# See http://btrfs.wiki.kernel.org for more information.
# Label:              (null)
# UUID:               4025b177-70ac-462b-9895-bdde1d6b3d0c
# Node size:          16384
# Sector size:        4096
# Filesystem size:    59.50GiB
# Block group profiles:
#   Data:             single            8.00MiB
#   Metadata:         DUP               1.00GiB
#   System:           DUP               8.00MiB
# SSD detected:       no
# Incompat features:  extref, skinny-metadata
# Checksum:           crc32c
# Number of devices:  1
# Devices:
#    ID        SIZE  PATH
#     1    59.50GiB  /dev/mapper/cryptdata
cryptdata is our root partition which we’ll use for the root filesystem.
Note that the SSD is not detected for me here, because I am running this in a Virtual Machine, but I will still pretend that I am on a SSD.
Step 3 (optional): Optimize mount options for SSD or NVME drives
Unfortunately, the Ubiquity installer does not set good mount options for btrfs on SSD or NVME drives, so you should change this for optimized performance and durability. I have found that there is some general agreement to use the following mount options:
  • ssd: use SSD specific options for optimal use on SSD and NVME
  • noatime: prevent frequent disk writes by instructing the Linux kernel not to store the last access time of files and folders
  • space_cache: allows btrfs to store free space cache on the disk to make caching of a block group much quicker
  • commit=120: time interval in which data is written to the filesystem (value of 120 is taken from Manjaro)
  • compress=zstd: allows to specify the compression algorithm which we want to use. btrfs provides lzo, zstd and zlib compression algorithms. Based on some Phoronix test cases, zstd seems to be the better performing candidate.
  • Lastly the pass flag for fschk in the fstab is useless for btrfs and should be set to 0.
We need to change two configuration files:
  • /usr/lib/partman/mount.d/70btrfs
  • /usr/lib/partman/fstab.d/btrfs
So let’s make a backup of these files first:
cp /usr/lib/partman/mount.d/70btrfs /usr/lib/partman/mount.d/70btrfs.bak
cp /usr/lib/partman/fstab.d/btrfs /usr/lib/partman/fstab.d/btrfs.bak
and then use an editor to change the following:
nano /usr/lib/partman/mount.d/70btrfs
# line 24: options="${options:+$options,}subvol=@,ssd,noatime,space_cache,commit=120,compress=zstd"
# line 31: options="${options:+$options,}subvol=@home,ssd,noatime,space_cache,commit=120,compress=zstd"
nano /usr/lib/partman/fstab.d/btrfs
# line 30: pass=0
# line 31: home_options="${options:+$options,}subvol=@home,ssd,noatime,space_cache,commit=120,compress=zstd"
# line 32: options="${options:+$options,}subvol=@,ssd,noatime,space_cache,commit=120,compress=zstd"
# line 36: pass=0
# line 37: options="${options:+$options,}subvol=@home,ssd,noatime,space_cache,commit=120,compress=zstd"
# line 40: pass=0
# line 56: echo "$home_path" "$home_mp" btrfs "$home_options" 0 0
Step 4: Install Ubuntu using the Ubiquity installer without the bootloader
Now let’s run the installation process, but without installing the bootloader, as we want to put /boot on an encrypted partition which is actually not allowed by Ubiquity. So we need to run the installer with:
ubiquity --no-bootloader
Choose the installation language, keyboard layout, Normal or Minimal installation, check the boxes of the Other options according to your needs. In the “Installation type” options choose “Something Else” and the manual partitioner will start:
  • Select /dev/vda1, press the Change button. Choose Use as ‘EFI System Partition’.
  • Select /dev/vda2, press the Change button. Choose Use as ‘swap area’ to create a swap partition. We will encrypt this partition later in the crypttab.
  • Select the root filesystem device for formatting (/dev/mapper/cryptdata type btrfs on top), press the Change button. Choose Use as ‘btrfs journaling filesystem’, check Format the partition and use ‘/’ as Mount point.
  • If you have other partitions, check their types and use; particularly,deactivate other EFI partitions.
Note that if you don’t declare a swap partition, the installer will create a swapfile, but for btrfs this needs to be in its own subvolume (otherwise we cannot take snapshots of @). I will show how to change this after the installation process finishes.
Recheck everything, press the Install Now button to write the changes to the disk and hit the Continue button. Select the time zone and fill out your user name and password. If your installation is successful choose the Continue Testing option. DO NOT REBOOT!, but return to your terminal.
Step 5: Post-Installation steps
Create a chroot environment and enter your system
Return to the terminal and create a chroot (change-root) environment to work directly inside your newly installed operating system:
mount -o subvol=@,ssd,noatime,space_cache,commit=120,compress=zstd /dev/mapper/cryptdata /mnt
for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; done
sudo cp /etc/resolv.conf /mnt/etc/
sudo chroot /mnt
Now you are actually inside your system, so let’s mount all other partitions and have a look at the btrfs subvolumes:
mount -av
# /                        : ignored
# /boot/efi                : successfully mounted
# /home                    : successfully mounted
# none                     : ignored
btrfs subvolume list /
# ID 256 gen 164 top level 5 path @
# ID 258 gen 30 top level 5 path @home
Looks great. Note that the subvolume @ is mounted to /, whereas the subvolume @home is mounted to /home.
Create crypttab
We need to create the crypttab manually:
export UUIDVDA3=$(blkid -s UUID -o value /dev/vda3) #this is an environmental variable
echo "cryptdata UUID=${UUIDVDA3} none luks" >> /etc/crypttab
cat /etc/crypttab
# cryptdata UUID=8e893c0f-4060-49e3-9d96-db6dce7466dc none luks
Note that the UUID is from the luks partition /dev/vda3, not from the device mapper /dev/mapper/cryptdata! You can get all UUID using blkid.
Encrypted swap
There are many ways to encrypt the swap partition, a good reference is dm-crypt/Swap encryption. For the sake of this guide, I will show how to set up both an encrypted swap partition as well as a swapfile which resides in its own btrfs subvolume. Choose the one you like more.
Option A: Swap partition
As I have no use for hibernation or suspend-to-disk, I will simply use a random password to decrypt the swap partition using the crypttab:
export SWAPUUID=$(blkid -s UUID -o value /dev/vda2)
echo "cryptswap UUID=${SWAPUUID} /dev/urandom swap,offset=1024,cipher=aes-xts-plain64,size=512" >> /etc/crypttab
cat /etc/crypttab
# cryptswap UUID=9cae34c0-3755-43b1-ac05-2173924fd433 /dev/urandom swap,offset=1024,cipher=aes-xts-plain64,size=512
We also need to adapt the fstab accordingly:
cp /etc/fstab /etc/fstab.bak
sed -i "s|UUID=${SWAPUUID}|/dev/mapper/cryptswap|" /etc/fstab
cat /etc/fstab
# /dev/mapper/cryptdata /               btrfs   defaults,subvol=@,ssd,noatime,space_cache,commit=120,compress=zstd 0       0
# UUID=01DE-F282  /boot/efi       vfat    umask=0077      0       1
# /dev/mapper/cryptdata /home           btrfs   defaults,subvol=@home,ssd,noatime,space_cache,commit=120,compress=zstd 0       0
# /dev/mapper/cryptswap none            swap    sw              0       0
The sed command simply replaced the UUID of your swap partition with the encrypted device called /dev/mapper/cryptswap. There you go, you have an encrypted swap partition. Alternatively, or additionally, you can set up a swapfile, or skip to the next step.
Option B: Swapfile
Swapfiles used to be a tricky business on btrfs, as it messed up snapshots and compression, but recent kernels are able to handle swapfile correctly if one puts them in a dedicated subvolume, in our case this will be called @swap. (Note, though, that if you plan to set up a RAID1 using btrfs you have to deactivate the swapfile again as this is still not supported in a RAID1 managed by btrfs.)
If you did not create a swap partition above, Ubiquity created a swapfile for you. Let’s remove this file and also any reference to it in the fstab:
swapoff /swapfile
rm /swapfile
sed -i '\|^/swapfile|d' /etc/fstab #this removes any lines starting with /swapfile
Next we mount the top-level root btrfs filesystem, which always has id 5, to /btrfs_pool:
mkdir /btrfs_pool
mount -o subvolid=5 /dev/mapper/cryptdata /btrfs_pool
ls /btrfs_pool
# @  @home
Note that we now look from the outside on our system, i.e. in @ we have the same files as in /, in @home the same files as in /home. Let’s create another subvolume called @swap:
btrfs subvolume create /btrfs_pool/@swap
ls /btrfs_pool
# @  @home  @swap
and create a 4GB swapfile inside this subvolume (change the size according to your needs) and set the necessary properties for btrfs:
truncate -s 0 /btrfs_pool/@swap/swapfile
chattr +C /btrfs_pool/@swap/swapfile
btrfs property set /btrfs_pool/@swap/swapfile compression none
fallocate -l 4G /btrfs_pool/@swap/swapfile
chmod 600 /btrfs_pool/@swap/swapfile
mkswap /btrfs_pool/@swap/swapfile
# Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
# no label, UUID=2c39e8bd-c158-4126-8389-5d56c0977db0
mkdir /btrfs_pool/@/swap
Note that in the last line we created the folder /swap to mount @swap to it via the fstab. So, let’s make the necessary change with a text editor, e.g.:
nano /etc/fstab
or these sed commands
echo "UUID=$(blkid -s UUID -o value /dev/mapper/cryptdata)   /swap   btrfs   subvol=@swap,compress=no   0 0" >> /etc/fstab
echo "/swap/swapfile none swap defaults 0 0" >> /etc/fstab
Either way your fstab should look like this:
cat /etc/fstab
# UUID=aa90f2d3-10d9-420b-86e2-92ffce0ece9d   /swap   btrfs   subvol=@swap,compress=no   0 0
# /swap/swapfile none swap defaults 0 0
We are done with swap and can unmount the top-level root filesystem:
umount /btrfs_pool
Add a key-file to type luks passphrase only once (optional, but recommended)
The device holding the kernel (and the initramfs image) is unlocked by GRUB, but the root device needs to be unlocked again at initramfs stage, regardless whether it’s the same device or not, so you’ll get a second prompt for your passphrase. This is because GRUB boots with the given vmlinuz and initramfs images; in other words, all devices are locked, and the root device needs to be unlocked again. To avoid extra passphrase prompts at initramfs stage, a workaround is to unlock via key files stored into the initramfs image. This can also be used to unlock any additional luks partitions you want on your disk. Since the initramfs image now resides on an encrypted device, this still provides protection for data at rest. After all for luks the volume key can already be found by user space in the Device Mapper table, so one could argue that including key files to the initramfs image – created with restrictive permissions – doesn’t change the threat model for luks devices. Note that this is exactly what e.g. the Manjaro architect installer does as well.
Long story short, let’s create a key-file, secure it, and add it to our luks volume:
mkdir /etc/luks
dd if=/dev/urandom of=/etc/luks/boot_os.keyfile bs=4096 count=1
# 1+0 records in
# 1+0 records out
# 4096 bytes (4.1 kB, 4.0 KiB) copied, 0.000928939 s, 4.4 MB/s
chmod u=rx,go-rwx /etc/luks
chmod u=r,go-rwx /etc/luks/boot_os.keyfile
cryptsetup luksAddKey /dev/vda3 /etc/luks/boot_os.keyfile
# Enter any existing passphrase:
cryptsetup luksDump /dev/vda3 | grep "Key Slot"
# Key Slot 0: ENABLED
# Key Slot 1: ENABLED
# Key Slot 2: DISABLED
# Key Slot 3: DISABLED
# Key Slot 4: DISABLED
# Key Slot 5: DISABLED
# Key Slot 6: DISABLED
# Key Slot 7: DISABLED
Note that “Key Slot 0” contains our passphrase, whereas “Key Slot 1” contains the key-file. Let’s restrict the pattern of keyfiles and avoid leaking key material for the initramfs hook:
echo "KEYFILE_PATTERN=/etc/luks/*.keyfile" >> /etc/cryptsetup-initramfs/conf-hook
echo "UMASK=0077" >> /etc/initramfs-tools/initramfs.conf
These commands will harden the security options in the intiramfs configuration file and hook.
Next, add the keyfile to your crypttab:
cp /etc/crypttab /etc/crypttab.bak
sed -i "s|none|/etc/luks/boot_os.keyfile|" /etc/crypttab # this replaces none with /etc/luks/boot_os.keyfile
cat /etc/crypttab
# cryptdata UUID=8e893c0f-4060-49e3-9d96-db6dce7466dc /etc/luks/boot_os.keyfile luks
Install the EFI bootloader
Now it is time to finalize the setup and install the GRUB bootloader. First we need to make it capable to unlock luks1-type partitions by setting GRUB_ENABLE_CRYPTODISK=y in /etc/default/grub, then install the bootloader to the device /dev/vda and lastly update GRUB. Just in case, I also reinstall the generic kernel (“linux-generic” and “linux-headers-generic”) and also install the Hardware Enablement kernel (“linux-generic-hwe-20.04” “linux-headers-generic-hwe-20.04”):
echo "GRUB_ENABLE_CRYPTODISK=y" >> /etc/default/grub
apt install -y --reinstall grub-efi-amd64-signed linux-generic linux-headers-generic linux-generic-hwe-20.04 linux-headers-generic-hwe-20.04
# --- SOME APT INSTALLATION OUTPUT ---
update-initramfs -c -k all
# update-initramfs: Generating /boot/initrd.img-5.4.0-26-generic
# update-initramfs: Generating /boot/initrd.img-5.4.0-29-generic
grub-install /dev/vda
# Installing for x86_64-efi platform.
# Installation finished. No error reported.
update-grub
# Sourcing file `/etc/default/grub'
# Sourcing file `/etc/default/grub.d/init-select.cfg'
# Generating grub configuration file ...
# Found linux image: /boot/vmlinuz-5.4.0-29-generic
# Found initrd image: /boot/initrd.img-5.4.0-29-generic
# Found linux image: /boot/vmlinuz-5.4.0-26-generic
# Found initrd image: /boot/initrd.img-5.4.0-26-generic
# Adding boot menu entry for UEFI Firmware Settings
# done
Lastly, double-check that the initramfs image has restrictive permissions and includes the keyfile:
stat -L -c "%A  %n" /boot/initrd.img
# -rw-------  /boot/initrd.img
lsinitramfs /boot/initrd.img | grep "^cryptroot/keyfiles/"
# cryptroot/keyfiles/cryptdata.key
Note that cryptsetup-initramfs may rename key files inside the initramfs.
Step 6: Reboot, some checks, and update system
Now, it is time to exit the chroot - cross your fingers - and reboot the system:
exit
# exit
reboot now
If all went well you should see a single passphrase prompt (YAY!) from GRUB:
Enter the passphrase for hd0,gpt3 (some very long number):
where you enter the luks passphrase to unlock GRUB, which then either asks you again for your passphrase or uses the key-file to unlock /dev/vda3 and map it to /dev/mapper/cryptdata. If you added a key-file you need to type your password only once. Note that if you mistyped the password for GRUB, you must restart the computer and retry.
Now let’s click through the welcome screen and open up a terminal to see whether everything is set up correctly:
sudo cat /etc/crypttab
sudo cat /etc/fstab
sudo mount -av
# /                        : ignored
# /boot/efi                : already mounted
# /home                    : already mounted
# none                     : ignored
# /swap                    : already mounted
# none                     : ignored
sudo mount -v | grep /dev/mapper
# /dev/mapper/cryptdata on / type btrfs (rw,noatime,compress=zstd:3,ssd,space_cache,commit=120,subvolid=256,subvol=/@)
# /dev/mapper/cryptdata on /swap type btrfs (rw,relatime,compress=zstd:3,ssd,space_cache,commit=120,subvolid=262,subvol=/@swap)
# /dev/mapper/cryptdata on /home type btrfs (rw,noatime,compress=zstd:3,ssd,space_cache,commit=120,subvolid=258,subvol=/@home)
sudo swapon
# NAME           TYPE      SIZE USED PRIO
# /swap/swapfile file        4G   0B   -2
# /dev/dm-1      partition   4G   0B   -3
sudo btrfs filesystem show /
# Label: none  uuid: aa90f2d3-10d9-420b-86e2-92ffce0ece9d
# 	Total devices 1 FS bytes used 6.61GiB
# 	devid    1 size 59.50GiB used 9.02GiB path /dev/mapper/cryptdata
sudo btrfs subvolume list /
# ID 256 gen 195 top level 5 path @
# ID 258 gen 192 top level 5 path @home
# ID 262 gen 180 top level 5 path @swap
Look’s good. Note that in this tutorial I installed both a swapfile and a swap partition. Normally you would choose one or the other.
Let’s update the system and reboot one more time:
sudo apt update
sudo apt upgrade
sudo apt dist-upgrade
sudo apt autoremove
sudo apt autoclean
Optionally, if you installed on a SSD and NVME, enable fstrim.timer as we did not add discard to the crypttab. This is due to the fact that Btrfs Async Discard Support Looks To Be Ready For Linux 5.6 is quite new, but 20.04 still runs kernel 5.4, it is better to enable the fstrim.timer systemd service:
sudo systemctl enable fstrim.timer
Now reboot:
sudo reboot now
Step 7: Install Timeshift, timeshift-autosnap-apt and grub-btrfs
Open a terminal and install some dependencies:
sudo apt install -y btrfs-progs git make
Install Timeshift and configure it directly via the GUI:
sudo apt install timeshift
sudo timeshift-gtk
  • Select “BTRFS” as the “Snapshot Type”; continue with “Next”
  • Choose your BTRFS system partition as “Snapshot Location”; continue with “Next”
  • “Select Snapshot Levels” (type and number of snapshots that will be automatically created and managed/deleted by Timeshift), my recommendations:
    • Activate “Monthly” and set it to 1
    • Activate “Weekly” and set it to 3
    • Activate “Daily” and set it to 5
    • Deactivate “Hourly”
    • Activate “Boot” and set it to 3
    • Activate “Stop cron emails for scheduled tasks”
    • continue with “Next”
    • I also include the @home subvolume (which is not selected by default). Note that when you restore a snapshot Timeshift you get the choise whether you want to restore it as well (which in most cases you don’t want to).
    • Click “Finish”
  • “Create” a manual first snapshot & exit Timeshift
Timeshift will now check every hour if snapshots (“hourly”, “daily”, “weekly”, “monthly”, “boot”) need to be created or deleted. Note that “boot” snapshots will not be created directly but about 10 minutes after a system startup.
Timeshift puts all snapshots into /run/timeshift/backup. Conveniently, the real root (subvolid 5) of your BTRFS partition is also mounted here, so it is easy to view, create, delete and move around snapshots manually.
ls /run/timeshift/backup
# @  @home  @swap  timeshift-btrfs
Note that /run/timeshift/backup/@ contains your / folder, /run/timeshift/backup/@home contains your /home folder, /run/timeshift/backup/@swap contains your /swap folder.
Now let’s install timeshift-autosnap-apt and grub-btrfs from GitHub
git clone https://github.com/wmutschl/timeshift-autosnap-apt.git /home/$USER/timeshift-autosnap-apt
cd /home/$USER/timeshift-autosnap-apt
sudo make install
git clone https://github.com/Antynea/grub-btrfs.git /home/$USER/grub-btrfs
cd /home/$USER/grub-btrfs
sudo make install
After this, optionally, make changes to the configuration files:
sudo nano /etc/timeshift-autosnap-apt.conf
sudo nano /etc/default/grub-btrfs/config
For example, as we don’t have a dedicated /boot partition, we can set snapshotBoot=false in the timeshift-autosnap-apt-conf file to not rsync the /boot directory to /boot.backup. Note that the EFI partition is still rsynced into your snapshot to /boot.backup/efi. For grub-btrfs, I change GRUB_BTRFS_SUBMENUNAME to “MY BTRFS SNAPSHOTS”.
Check if everything is working:
sudo timeshift-autosnap-apt
Now, if you run sudo apt install|remove|upgrade|dist-upgrade, timeshift-autosnap-apt will create a snapshot of your system with Timeshift and grub-btrfs creates the corresponding boot menu entries (actually it creates boot menu entries for all subvolumes of your system).
FINISHED! CONGRATULATIONS AND THANKS FOR STICKING THROUGH!
btrfs is my favorite too, with it one can easily create subvol to do a lot of things, like install multiple Linux distros on same disk without repartioning/formating; quicking setup restore points.
btrfs consumes much less ram so it welcomes less powerful or older machines.
Really hope that Ubuntu can put more efforts on this FS alone side ZFS.
I don’t think so. Ubuntu has already put much effort into ZFS and will continue to push this. They have a series of blog posts (ZFS focus on Ubuntu 20.04 LTS blog posts - Desktop - Ubuntu Community Hub) that sound very promising. So I guess, I’ll be switching to ZFS in 20.10 once they include full disk encryption.
By the way, the latest Linux Unplugged podcast no 358 Chris also makes some good points about Btrfs.
I may try again zfs on Ubuntu; the experience on 19.10 wasn’t really good, maybe my machine is not good enough.
For some reason I cannot edit the first post, so just to let everyone know, I’ve updated the guide slightly as there were some inconsistencies. The updated guides for Pop!_OS, Ubuntu or Manjaro (with or without RAID1) can be found here:
https://mutschler.eu/linux/install-guides/
There’s an arbitrary limit on how old a post can be for an edit, ill bring it up.
I’ve temporarily adjusted the date on your post so you can edit it in the meantime.
