Hi all. I recently re-installed the latest Manjaro Budgie edition. I ran it for about 3 months and didn’t have this issue, but now I’m lost.
Manjaro itself is reporting the time and date correctly. I have NTP set up and no issues. My problem is that both Proton Mail and Facebook Messenger seem to think I sent or received an email or message 4 hours later than I did. For example, I received an email at 1149 Eastern, but Proton shows that it came in at 1649. As I’m typing this, it’s not yet even 1649. I have the same issues with FB Messenger. Both apps on my phone display the correct times. The really weird thing is that Proton Calendar shows the correct time.
When I first noticed it on Proton, I made sure that my settings there had the right time zone and it does. Same with Facebook. I’m using LibreWolf browser, if that makes any difference.
It’s not a life or death thing, just very annoying. If anyone can guide me in the right direction, I’d really appreciate it.
Have a look into the language setting of ProtonMail or even in LibreWolf. Could be that your browser is using the wrong locale? If you have another browser try to see if you see the same issue.
Okay, I tried Firefox and had no issues with the time. I ended up finding a post on Reddit. When I changed the flag mentioned in the post and restarted LibreWolf, all is good. Thanks for the input everyone!
I guess because I’m new to the forums, I can’t post a link or screenshot to where I found the solution.
