I get mails from my energyprovider, for instance with a link so i can download my bill or some other.
When i click on the link it opens Firefox, (Newest version, downloaded and installed from the site) but nothing happens. It’s a blank firefox window. Accesing the preferences for instance, won’t work either in this particular window.
What does work is this; if i open Firefox first, and then click on the link in the mail, everything works just fine.
I had a look in the preferences of Firefox but saw nothing that wasn’t there before (no new options i could see).
Distribution & Version = Linux Mint 20.3
Kernel information = Linux Jimpson 5.4.0-99-generic #112-Ubuntu SMP Thu Feb 3 13:50:55 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
When did the issue start happening? = When i clicked the first link in a mail message.
Did anything change that caused it? = No.
What steps do you take that cause the problem? = None other than clicking a link in a e-mail message.
Anybody got an idea where this comes from? Or is this a growing pain of a new version?
Sounds strange. But anyway what is set as the default browser on your install?
Also check your command because you installed Firefox manually. Does it open like this:
firefox %u
That means that whatever you want to open in a browser tab in Firefox, like a link, will be opened in a new browser window. Though it might be unrelated.
Oh yes, i’m sorry i didn’t mention that. I use Thunderbird. (With a protonmail bridge).
I’ve went over the settings in Thunderbird/Firefox prior to creating the topic, and nothing seems out of the ordinary. Nothing that wasn’t there before.
It’s strange behaviour which i haven’t encounter t yet in all these years of using Mint.
Unfortunately, it doesn’t work. The inspection window won’t even open. In another instance of the browser, there’s no problem.
I removed Firefox and my profile along with it, installed firefox from the software repo’s, hoping that might solve it, but no. Same problem.
I found out that the menu still works. Here’s a little screenshot of the error messages. (around 22 of the m).
The error code “this._browser.frameloader.remotetab is null” shows up in a search for problems with Firefox. A couple of entries seem to point to something called “FireJail” – but I have no idea what that is. Perhaps Firefox is being isolated and not receiving the initial data that is needed to hook to the desired site. (Just kind of thinking outloud.)
@MarkofCain thank you for the help. I’ll take a look.
@jastombaugh this happens with every email link. It doesn’t matter what the source is.
Thunderbird is indeed version 91.5.0
Edit: i posted my problem on the linux mint forum too and it seems i’m not the only one having this problem.
For now, some are saying that it’s hardware related, some are saying that it’s the new kernel version that is “acting up” and that i should switch to an older kernel. I’m not going to do that, because that got me in trouble the last time.
New fun. I just found out that i can’t open the downloadfolder from the browser, after downloading a file.
I need to navigate to the folder with nemo. Opening a file works.
Just checked and things are working as they should… but then realized that I’m still on Mint 20.2.
Could be a kernal bug after all. Is there a Firefox flatpak we could test with? I know the Mint team was intending on building Firefox especially for the Deb version while many distros were electing for a snap version. Sounds like some bugs could be surfacing?
I feel really compelled to suggest that you not click on links in emails. Especially emails that lead you to the login screen of a bank/utility co/government service/etc. That is the kind of habituated behavior that makes phishing work.
You should have all your account’s login pages carefully bookmarked and only use those bookmarks to access accounts. JMHO, of course, but you will end up auto-pilot clicking email links and get bit at some point.
Yep, in 99% of the cases i don’t click on links and i have the critical sites carefully bookmarked.
It’s in cases i know the sender (mostly family, friends) with things they want to convey. (and even then i’m sceptical/paranoid).
There’s no way i’d click on mission critical links, because like you say, that’s opening up to phishing.
It’s just the first time i’ve encounterd this behaviour.
Thank you for your concern though. Much appreciated!
