Do we need a separate category for the Steam Deck or do we pile it all in gaming?
Anyway felt a bit disappointed here with some games only making it into Playable and not Steam Deck Verified.
Borderlands 2 is verified while Borderlands 1 and 3 are listed only as playable. Tomb Raider is only listed as playable despite having a native build. Also Grim Dawn.
But I know that Grim Dawn only needs a few changes to controller config to play beautifully using a Steam Controller. Also Borderlands 3 played beautifully using the Steam Controller after I spent a bit of time setting it up so the controls were almost identical to Borderlands 2.
PacMan 256 and Obduction shouldn’t need much to play well on Steam Deck, same for Kingdom Two Crowns.
So was wondering if we could get some of the games in Playable that only required one or two steps to configure for the Steam Controller if you don’t currently have access to a Deck, or one or two steps to get them playing beautifully with the Steam Deck if you have access to the hardware. Feel free to pick your favourites if they are in Playable.
