Hey DL,
I recently switched to Kubuntu and I’ve hit a few paper cuts. I’m wondering if any of you have experience trouble shooting two of the largest issues:
When I boot up, the machine will wait at the grub menu for 30 seconds. I’ve edited my grub to be 0 seconds, or 5 seconds on the timeout but nothing seems to be working after I do a sudo update-grub
Here’s my grub file:
GRUB_DEFAULT=0 GRUB_TIMEOUT_STYLE=menu GRUB_TIMEOUT=0 GRUB_DISTRIBUTOR=
lsb_release -i -s 2> /dev/null || echo DebianGRUB_CMDLINE_LINUX_DEFAULT="quiet splash pci=noaer" GRUB_CMDLINE_LINUX="nouveau.modeset=0"
I’ve tried nouveau.modest=1 as well or blacklisting nouveau. I’m running the 470 Nvidia driver as my Titan GTX X is recently out of support (or so I thought).
The second issue I’m seeing is that after I use the systemctl-suspend command, when I wake up the computer from sleep nothing is responsive. I can tell the machine wakes as the fans start up, my RGB keyboard lights up, but I can’t type commands and the screen is black. The keyboard is unresponsive so I can’t even drop to TTY or follow my shortcuts to open a terminal and reboot, etc.
I will note that sudo pm-suspend
works perfectly, but it’s a pain to pass sudo every time rather than use a shortcut.
Anybody have any sage advice for these issues? My previous distro of several years on this machine never struggled with these particular problem points so it’s new territory for me.
Thank you!
