See image. Updates paused but metered connection box unchecked. How to fix this?
The solution should be something a newbie can implement.
This thread is relevant Automatic Updates Paused even though the connection is not metered (#996) · Issues · GNOME / gnome-software · GitLab but I was unable to follow all the posts that had lots of terminal commands. Is that the only way to fix this?
Can I get around this issue by just manually running ‘sudo apt update’ and ‘sudo apt upgrade’? Will that upgrade the same group of apps?
