My non Linux loving friends and I are meeting from time to time via Skype.
I was pleasantly surprised how easy it was to install Skype for Linux via snap, and overall it works well. I am not aware of any features my Windows running friends have that I don’t have.
However I have one annoyance with it. Whenever I login to my account Skype is launching automatically. I found no obvious way to disable this. I would like to start it up only when I plan to talk with my friends.
The instruction I found online about this assumes that I am logged into my Skype account, but I don’t want to do it, and I didn’t need to create an account just to have a chat with my friends.
Anybody have a suggestion how to block Skype from startup automatically?
P.S.
I am not looking for a suggestion of any other virtual meeting solution. We, as a group already tested several of them, and Skype is working just fine for us.
I have Skype installed and use it very rarely for that occasion when I want to talk to family members.
You have to go to the Skype options or preferences and I know you can turn off auto start.
Let me know if you can find that setting. If not I will open Skype here on my machine and check for it precisely.
PS: The toggle option should be in Skype → Settings → on the left sidebar General → Then look at the right side.
@Ethanol, I am running Kubuntu 20.04 (KDE 5.18.5) @vinylninja, @eastcoastweb - I suspected as much, but since I am not logged-in my Settings menu is grayed out.
I could replicate this with Lubuntu. I fixed the issue just by turning it off in startup applications. It was called “snap user application autostart helper”.
In KDE Plasma you’ll need to open the settings – > Startup and Shutdown
Then check the Autostart, or background services for the snap process
