This will work on Ubuntu, Debian and Arch Linux.
Running Pi-hole in LXD container
This guide was originally written for those who:
a) would like to try Pi-hole Network-wide Ad Blocking locally before buying a hardware
b) would like to use Pi-hole locally, only on one device
Later I decided that Pi-hole fits nice with LXD container, and added UFW configuration to allow requests from all clients.
What do we gain here from using an LXD container?
This allows Pi-hole web-interface on port 80 to coexist with any existing web-app on host, increases security for web-interface open to Internet, and simplifies deletion when testing is over.
Installing LXD and Pi-hole
First, install LXD
v. 3.0 LTS release, Ubuntu 18.04
sudo apt install lxd
or
v. 3.18 or newer (feature releases), Ubuntu 18.04 and newer, Debian 10, Arch Linux, or any other Linux that supports snaps
sudo snap install lxd
Do first time setup. Default answers are fine.
lxd init
From now on, use lxc command.
Create and start an Ubuntu 18.04 container named pihole
lxc launch ubuntu:18.04 pihole
Check that it started succesfully and has an IP
lxc list
Log into container, set the correct timezone
lxc exec pihole -- /bin/bash
dpkg-reconfigure tzdata
and install Pi-hole using the official guide.
Save the password shown by installer.
Log out: Ctrl + D
Tell the system to use the Pi-hole container as new DNS [1]
Go to internet connection settings and set container IP as DNS.
You can look up the IP:
lxc list
Restart your browser and open any website, then open Pi-hole admin page (it is on the same IP as DNS), log in and see your browser`s request in Query Log.
Optional: Allow connections from your network to container
Use UFW to allow connections to Pi-hole from other devices.
Source: https://gist.github.com/kimus/9315140
Edit /etc/default/ufw
DEFAULT_FORWARD_POLICY="ACCEPT"
Edit /etc/ufw/sysctl.conf
net.ipv4.ip_forward=1
Add the following to /etc/ufw/before.rules
just before the filter rules, be sure to replace wlp1s0 with your network interface and 10.81.65.206 with your container IP, 192.168.1.45 with your host IP.
# NAT table rules
*nat
:PREROUTING ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
# Port Forwardings
-A PREROUTING -i wlp1s0 -p tcp --dport 80 -j DNAT --to-destination 10.81.65.206
-A PREROUTING -i wlp1s0 -p tcp --dport 53 -j DNAT --to-destination 10.81.65.206
-A PREROUTING -i wlp1s0 -p udp --dport 53 -j DNAT --to-destination 10.81.65.206
# Allow access by local IP via wlp1s0 - change to match you out-interface
-A POSTROUTING -s 192.168.1.0/24 -o wlp1s0 -j SNAT --to-source 192.168.1.45
-A OUTPUT -d 192.168.1.45 -p tcp --dport 80 -j DNAT --to-destination 10.81.65.206
# don't delete the 'COMMIT' line or these nat table rules won't
# be processed
COMMIT
Enable changes by enabling UFW
sudo ufw enable
and rebooting the host machine.
You can now use Pi-hole in your network.
Removing container
Roll back whatever changes you did to network connection and UFW.
Stop and delete container:
lxc stop pihole
lxc delete pihole
Optionally delete LXD
sudo apt purge lxd
or
sudo snap remove lxd
Tips
[1] You can also set DNS for all internet connections.
Here is the how-to for NetworkManager.
Edit /etc/NetworkManager/NetworkManager.conf
Add:
<main>
dns=none
This will instruct NetworkManager to not make any changes to /etc/resolv.conf
Restart NetworkManager
sudo systemctl restart NetworkManager
Now edit /etc/resolv.conf
Delete everything, and put only:
nameserver your-container-ip
