I am attempting to back up ~ 10TB of data to some internal HDs. These drives are not used for any purpose other than bacula; indeed the whole server does nothing but bacula.
The problem is bacula keeps trying to write to a drive that it already filled. There are other drives that are still empty.
This is the output of “status Storage” from bconsole. You can see it knows Available Space=0 B on InternalC08, but it keeps trying to create a volume there anyway. At the bottom of this email I have included a portion of my bacula-sd.conf. Thank you in advance for any guidance you may provide. Even just referring me to a bacula forum would really help.
status Storage
*status Storage
Automatically selected Storage: bacula-sd
Connecting to Storage daemon bacula-sd at bacula:9103
bacula-sd Version: 9.4.2 (04 February 2019) x86_64-pc-linux-gnu ubuntu 20.04
Daemon started 11-Jun-20 00:01. Jobs: run=2, running=0.
Heap: heap=147,456 smbytes=332,838 max_bytes=333,032 bufs=184 max_bufs=186
Sizes: boffset_t=8 size_t=8 int32_t=4 int64_t=8 mode=0,0 newbsr=0
Res: ndevices=5 nautochgr=1
Running Jobs:
Writing: Incremental Backup job BaculaConfiguration JobId=76 Volume=""
pool="GlenAllen" device="InternalC08" (/media/ci08)
spooling=0 despooling=0 despool_wait=0
Files=0 Bytes=0 AveBytes/sec=0 LastBytes/sec=0
FDReadSeqNo=6 in_msg=6 out_msg=13 fd=5
Jobs waiting to reserve a drive:
Terminated Jobs:
JobId Level Files Bytes Status Finished Name
102 Incr 11 6.015 K OK 10-Jun-20 07:00 howardServerBackup
103 Full 77 1.072 G Error 10-Jun-20 07:03 zfsUncompressibleBackup
106 Full 1 28.14 M OK 10-Jun-20 07:30 BackupCatalog
104 Incr 0 0 Other 10-Jun-20 07:30 RyzenBackup
4 Full 148,141 7.413 T Error 10-Jun-20 14:30 zfsUncompressibleBackup
13 Incr 0 0 Error 10-Jun-20 14:30 BaculaConfiguration
25 Incr 0 0 Error 10-Jun-20 14:30 BaculaConfiguration
37 Incr 0 0 Cancel 11-Jun-20 00:01 BaculaConfiguration
49 Full 0 0 Error 11-Jun-20 00:01 BaculaConfiguration
50 Diff 0 0 Error 11-Jun-20 00:01 BaculaConfiguration
Device status:
Autochanger "InternalDrives" with devices:
"InternalB01" (/media/bi01)
"InternalD01" (/media/di01)
"InternalE04" (/media/ei04)
"InternalF01" (/media/fi01)
Device File: "InternalB01" (/media/bi01) is not open.
Drive 0 is not loaded.
Available Space=869.3 GB
Device File: "InternalC08" (/media/ci08) is not open.
Device is BLOCKED waiting to create a volume for:
Pool: GlenAllen
Media type: IntHDDc
Available Space=0 B
Device File: "InternalD01" (/media/di01) is not open.
Available Space=933.3 GB
Device File: "InternalE04" (/media/ei04) is not open.
Available Space=3.736 TB
Device File: "InternalF01" (/media/fi01) is not open.
Used Volume status:
Reserved volume: GlenAllen195 on File device "InternalC08" (/media/ci08)
Reader=0 writers=0 reserves=1 volinuse=0 worm=0
excerpt from config files
Autochanger {
Name = InternalDrives
Device = InternalB01, InternalC08, InternalD01, InternalE04, InternalF01, InternalB01
Changer Command = /dev/null
Changer Device = /dev/null
Device {
Name = InternalB01
Media Type = IntHDDb
Device Type = File
Archive Device = /media/bi01 # WDC WD10EFRX-68P
LabelMedia = yes # lets Bacula label unlabeled media
Random Access = Yes
AutomaticMount = yes # when device opened, read it
RemovableMedia = no
AlwaysOpen = no
Maximum Concurrent Jobs = 2;
Device {
Name = InternalC08
Media Type = IntHDDc
Device Type = File
Archive Device = /media/ci08 # HGST HUH721008AL
Random Access = Yes
RemovableMedia = no
AlwaysOpen = no
