Just to let everybody know, I have found a place to find hardware compatibility for Linux using Linux-Hardware.org. This is a large database of computer hardware
where users can test their system for compatibility. An in depth list shows parts
that are tested working or not. At the top of the list, there is information showing
the kernel used, the desktop, distro etc. If you want to test your hardware,
Hardware Probe is available as a flatpak. Any further resources are welcome.
Thanks for sharing. That’s a good resource. I’ll look into it further. Any idea if there are standardized benchmarks to determine if one distro gets better performance than another out of the same hardware?
I haven’t found any resources for finding benchmarks for Linux distros.
