Just got a good deal on a Lenovo ThinkCentre M910t on eBay. It looks like it has a spot for a front fan, but I’m not sure what size it is. It looks like either an 80mm or 92mm. Anybody had experience with this computer?
I don’t have this computer. But here is the Hardware Maintenance Guide for that unit:
You could measure the distance between the mounting holes and match it up with a Noctura Fan. The Noctura specifications say that their 92mm fans mount on holes that are 82.5 mm apart.
Ok, awesome! Thanks for the info, I’ll check it out.
