Looking at the bootup logs it seems to still be failing back to nouveau? (bold line)
Dec 17 19:54:25 oryx kernel: Command line: BOOT_IMAGE=(hd0,gpt2)/vmlinuz-5.3.16-300.fc31.x86_64 root=/dev/mapper/luks-80b40500-d0a8-4fe6-82b0-1f837e3f860c ro crashkernel=128M resume=/dev/mapper/samsungpro-swap rd.luks.uuid=luks-28a349b9-d708-484d-94e5-56dca66531a1 rd.luks.uuid=luks-80b40500-d0a8-4fe6-82b0-1f837e3f860c rd.lvm.lv=samsungpro/root rd.lvm.lv=samsungpro/swap rhgb quiet rd.driver.blacklist=nouveau modprobe.blacklist=nouveau nvidia-drm.modeset=1
Dec 17 19:54:25 oryx kernel: Kernel command line: BOOT_IMAGE=(hd0,gpt2)/vmlinuz-5.3.16-300.fc31.x86_64 root=/dev/mapper/luks-80b40500-d0a8-4fe6-82b0-1f837e3f860c ro crashkernel=128M resume=/dev/mapper/samsungpro-swap rd.luks.uuid=luks-28a349b9-d708-484d-94e5-56dca66531a1 rd.luks.uuid=luks-80b40500-d0a8-4fe6-82b0-1f837e3f860c rd.lvm.lv=samsungpro/root rd.lvm.lv=samsungpro/swap rhgb quiet rd.driver.blacklist=nouveau modprobe.blacklist=nouveau nvidia-drm.modeset=1
Dec 17 19:54:25 oryx dracut-cmdline[363]: Using kernel command line parameters: BOOT_IMAGE=(hd0,gpt2)/vmlinuz-5.3.16-300.fc31.x86_64 root=/dev/mapper/luks-80b40500-d0a8-4fe6-82b0-1f837e3f860c ro crashkernel=128M resume=/dev/mapper/samsungpro-swap rd.luks.uuid=luks-28a349b9-d708-484d-94e5-56dca66531a1 rd.luks.uuid=luks-80b40500-d0a8-4fe6-82b0-1f837e3f860c rd.lvm.lv=samsungpro/root rd.lvm.lv=samsungpro/swap rhgb quiet rd.driver.blacklist=nouveau modprobe.blacklist=nouveau nvidia-drm.modeset=1
Dec 17 19:55:07 oryx kernel: nvidia: loading out-of-tree module taints kernel.
Dec 17 19:55:07 oryx kernel: nvidia: module license ‘NVIDIA’ taints kernel.
Dec 17 19:55:07 oryx kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Dec 17 19:55:07 oryx kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 237
Dec 17 19:55:07 oryx kernel: nvidia 0000:01:00.0: enabling device (0106 → 0107)
Dec 17 19:55:07 oryx kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
Dec 17 19:55:07 oryx kernel: nvidia-uvm: Loaded the UVM driver, major device number 235.
Dec 17 19:55:07 oryx systemd-udevd[1012]: nvidia: Process ‘/usr/bin/bash -c ‘/usr/bin/mknod -Z -m 666 /dev/nvidiactl c 195 255’’ failed with exit code 1.
Dec 17 19:55:07 oryx systemd-udevd[1012]: nvidia: Process ‘/usr/bin/bash -c ‘for i in $(cat /proc/driver/nvidia/gpus/*/information | grep Minor | cut -d \ -f 4); do /usr/bin/mknod -Z -m 666 /dev/nvidia${i} c 195 ${i}; done’’ failed with exit code 1.
Dec 17 19:55:07 oryx kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 440.44 Sun Dec 8 03:29:48 UTC 2019
Dec 17 19:55:07 oryx kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
Dec 17 19:55:08 oryx kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
Dec 17 19:55:09 oryx audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=abrt-xorg comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Dec 17 19:55:10 oryx systemd[1]: Condition check resulted in Fallback to nouveau as nvidia did not load being skipped.
Dec 17 19:55:10 oryx /usr/libexec/gdm-x-session[1579]: (–) Log file renamed from “/var/lib/gdm/.local/share/xorg/Xorg.pid-1582.log” to “/var/lib/gdm/.local/share/xorg/Xorg.0.log”
Dec 17 19:55:10 oryx /usr/libexec/gdm-x-session[1579]: Kernel command line: BOOT_IMAGE=(hd0,gpt2)/vmlinuz-5.3.16-300.fc31.x86_64 root=/dev/mapper/luks-80b40500-d0a8-4fe6-82b0-1f837e3f860c ro crashkernel=128M resume=/dev/mapper/samsungpro-swap rd.luks.uuid=luks-28a349b9-d708-484d-94e5-56dca66531a1 rd.luks.uuid=luks-80b40500-d0a8-4fe6-82b0-1f837e3f860c rd.lvm.lv=samsungpro/root rd.lvm.lv=samsungpro/swap rhgb quiet rd.driver.blacklist=nouveau modprobe.blacklist=nouveau nvidia-drm.modeset=1
Dec 17 19:55:10 oryx /usr/libexec/gdm-x-session[1579]: Build ID: xorg-x11-server 1.20.6-1.fc31
Dec 17 19:55:10 oryx /usr/libexec/gdm-x-session[1579]: (==) Log file: “/var/lib/gdm/.local/share/xorg/Xorg.0.log”, Time: Tue Dec 17 19:55:10 2019
Dec 17 19:55:10 oryx /usr/libexec/gdm-x-session[1579]: (==) Using config file: “/etc/X11/xorg.conf”
Dec 17 19:55:10 oryx /usr/libexec/gdm-x-session[1579]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Dec 17 19:55:10 oryx /usr/libexec/gdm-x-session[1579]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Dec 17 19:55:10 oryx /usr/libexec/gdm-x-session[1579]: (==) ModulePath set to “/usr/lib64/xorg/modules”
Dec 17 19:55:10 oryx /usr/libexec/gdm-x-session[1579]: (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
Dec 17 19:55:10 oryx /usr/libexec/gdm-x-session[1579]: (II) LoadModule: “nvidia”
Dec 17 19:55:10 oryx /usr/libexec/gdm-x-session[1579]: (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
Dec 17 19:55:10 oryx /usr/libexec/gdm-x-session[1579]: (II) Module nvidia: vendor=“NVIDIA Corporation”
Dec 17 19:55:11 oryx /usr/libexec/gdm-x-session[1579]: (II) Loading /usr/lib64/xorg/modules/libfb.so
Dec 17 19:55:11 oryx /usr/libexec/gdm-x-session[1579]: (II) Loading /usr/lib64/xorg/modules/libwfb.so
Dec 17 19:55:11 oryx /usr/libexec/gdm-x-session[1579]: (II) Applying OutputClass “nvidia” options to /dev/dri/card1
Dec 17 19:55:11 oryx /usr/libexec/gdm-x-session[1579]: (II) Loading sub module “glxserver_nvidia”
Dec 17 19:55:11 oryx /usr/libexec/gdm-x-session[1579]: (II) LoadModule: “glxserver_nvidia”
Dec 17 19:55:11 oryx /usr/libexec/gdm-x-session[1579]: (II) Loading /usr/lib64/xorg/modules/extensions/libglxserver_nvidia.so
Dec 17 19:55:11 oryx /usr/libexec/gdm-x-session[1579]: (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
Dec 17 19:55:11 oryx /usr/libexec/gdm-x-session[1579]: (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
Dec 17 19:55:11 oryx /usr/libexec/gdm-x-session[1579]: (II) NVIDIA(0): “DFP-4:nvidia-auto-select,DFP-2:nvidia-auto-select”
Dec 17 19:55:11 oryx /usr/libexec/gdm-x-session[1579]: (WW) NVIDIA: ‘/var/run/nvidia-xdriver-5ac29685’ Permission denied
Dec 17 19:55:11 oryx /usr/libexec/gdm-x-session[1579]: (II) NVIDIA(0): Setting mode “DFP-4:nvidia-auto-select,DFP-2:nvidia-auto-select”
Dec 17 19:55:11 oryx /usr/libexec/gdm-x-session[1579]: (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
Dec 17 19:55:11 oryx /usr/libexec/gdm-x-session[1579]: (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
Dec 17 19:55:11 oryx /usr/libexec/gdm-x-session[1579]: (II) NVIDIA(0): Setting mode “DP-3: nvidia-auto-select @1440x900 +0+0 {ViewPortIn=1440x900, ViewPortOut=1440x900+0+0}, HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}”
Dec 17 19:55:11 oryx /usr/libexec/gdm-x-session[1579]: (II) NVIDIA(0): Setting mode “DP-3: nvidia-auto-select @1440x900 +1920+0 {ViewPortIn=1440x900, ViewPortOut=1440x900+0+0}, HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}”
Dec 17 19:55:23 oryx /usr/libexec/gdm-x-session[2336]: (–) Log file renamed from “/home/jared/.local/share/xorg/Xorg.pid-2339.log” to “/home/jared/.local/share/xorg/Xorg.1.log”
Dec 17 19:55:23 oryx /usr/libexec/gdm-x-session[2336]: Kernel command line: BOOT_IMAGE=(hd0,gpt2)/vmlinuz-5.3.16-300.fc31.x86_64 root=/dev/mapper/luks-80b40500-d0a8-4fe6-82b0-1f837e3f860c ro crashkernel=128M resume=/dev/mapper/samsungpro-swap rd.luks.uuid=luks-28a349b9-d708-484d-94e5-56dca66531a1 rd.luks.uuid=luks-80b40500-d0a8-4fe6-82b0-1f837e3f860c rd.lvm.lv=samsungpro/root rd.lvm.lv=samsungpro/swap rhgb quiet rd.driver.blacklist=nouveau modprobe.blacklist=nouveau nvidia-drm.modeset=1
Dec 17 19:55:23 oryx /usr/libexec/gdm-x-session[2336]: Build ID: xorg-x11-server 1.20.6-1.fc31
Dec 17 19:55:23 oryx /usr/libexec/gdm-x-session[2336]: (==) Log file: “/home/jared/.local/share/xorg/Xorg.1.log”, Time: Tue Dec 17 19:55:23 2019
Dec 17 19:55:23 oryx /usr/libexec/gdm-x-session[2336]: (==) Using config file: “/etc/X11/xorg.conf”
Dec 17 19:55:23 oryx /usr/libexec/gdm-x-session[2336]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Dec 17 19:55:23 oryx /usr/libexec/gdm-x-session[2336]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Dec 17 19:55:23 oryx /usr/libexec/gdm-x-session[2336]: (==) ModulePath set to “/usr/lib64/xorg/modules”
Dec 17 19:55:23 oryx /usr/libexec/gdm-x-session[2336]: (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
Dec 17 19:55:23 oryx /usr/libexec/gdm-x-session[2336]: (II) LoadModule: “nvidia”
Dec 17 19:55:23 oryx /usr/libexec/gdm-x-session[2336]: (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
Dec 17 19:55:23 oryx /usr/libexec/gdm-x-session[2336]: (II) Module nvidia: vendor=“NVIDIA Corporation”
Dec 17 19:55:24 oryx /usr/libexec/gdm-x-session[2336]: (II) Loading /usr/lib64/xorg/modules/libfb.so
Dec 17 19:55:24 oryx /usr/libexec/gdm-x-session[2336]: (II) Loading /usr/lib64/xorg/modules/libwfb.so
Dec 17 19:55:24 oryx /usr/libexec/gdm-x-session[2336]: (II) Applying OutputClass “nvidia” options to /dev/dri/card1
Dec 17 19:55:24 oryx /usr/libexec/gdm-x-session[2336]: (II) Loading sub module “glxserver_nvidia”
Dec 17 19:55:24 oryx /usr/libexec/gdm-x-session[2336]: (II) LoadModule: “glxserver_nvidia”
Dec 17 19:55:24 oryx /usr/libexec/gdm-x-session[2336]: (II) Loading /usr/lib64/xorg/modules/extensions/libglxserver_nvidia.so
Dec 17 19:55:24 oryx /usr/libexec/gdm-x-session[2336]: (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
Dec 17 19:55:24 oryx /usr/libexec/gdm-x-session[2336]: (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
Dec 17 19:55:24 oryx /usr/libexec/gdm-x-session[2336]: (II) NVIDIA(0): “DFP-4:nvidia-auto-select,DFP-2:nvidia-auto-select”
Dec 17 19:55:24 oryx /usr/libexec/gdm-x-session[2336]: (WW) NVIDIA: ‘/var/run/nvidia-xdriver-a4e6dd2f’ Permission denied
Dec 17 19:55:24 oryx /usr/libexec/gdm-x-session[2336]: (II) NVIDIA(0): Setting mode “DFP-4:nvidia-auto-select,DFP-2:nvidia-auto-select”
Dec 17 19:55:24 oryx /usr/libexec/gdm-x-session[2336]: (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
Dec 17 19:55:24 oryx /usr/libexec/gdm-x-session[2336]: (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
Dec 17 19:55:24 oryx /usr/libexec/gdm-x-session[2336]: (II) NVIDIA(0): Setting mode “DP-3: nvidia-auto-select @1440x900 +0+0 {ViewPortIn=1440x900, ViewPortOut=1440x900+0+0}, HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}”
Dec 17 19:55:24 oryx /usr/libexec/gdm-x-session[2336]: (II) NVIDIA(0): Setting mode “DP-3: nvidia-auto-select @1440x900 +1920+0 {ViewPortIn=1440x900, ViewPortOut=1440x900+0+0}, HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}”
Dec 17 19:57:32 oryx kernel: Modules linked in: rfcomm ccm xt_CHECKSUM xt_MASQUERADE nf_nat_tftp nf_conntrack_tftp tun bridge stp llc nf_conntrack_netbios_ns nf_conntrack_broadcast xt_CT ip6t_REJECT nf_reject_ipv6 ip6t_rpfilter ipt_REJECT nf_reject_ipv4 xt_conntrack ebtable_nat ebtable_broute ip6table_nat ip6table_mangle ip6table_raw ip6table_security iptable_nat nf_nat iptable_mangle iptable_raw iptable_security nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c ip_set nfnetlink ebtable_filter ebtables ip6table_filter ip6_tables iptable_filter cmac bnep sunrpc vfat fat snd_soc_skl snd_soc_hdac_hda snd_hda_ext_core snd_soc_skl_ipc snd_soc_sst_ipc snd_soc_sst_dsp snd_soc_acpi_intel_match x86_pkg_temp_thermal snd_soc_acpi iwlmvm snd_hda_codec_realtek intel_powerclamp snd_hda_codec_hdmi snd_soc_core iTCO_wdt coretemp snd_hda_codec_generic nvidia_drm(POE) mac80211 iTCO_vendor_support nvidia_modeset(POE) ledtrig_audio intel_rapl_msr snd_compress kvm_intel ac97_bus snd_pcm_dmaengine snd_hda_intel system76(OE)
Dec 17 19:57:32 oryx kernel: libarc4 snd_hda_codec kvm nvidia_uvm(OE) uvcvideo snd_hda_core btusb videobuf2_vmalloc irqbypass videobuf2_memops btrtl intel_cstate iwlwifi snd_hwdep videobuf2_v4l2 btbcm snd_seq intel_uncore btintel videobuf2_common snd_seq_device bluetooth snd_pcm intel_rapl_perf nvidia(POE) videodev wmi_bmof rtsx_pci_ms snd_timer cfg80211 joydev memstick mc ecdh_generic i2c_i801 snd ecc ipmi_devintf soundcore idma64 ipmi_msghandler processor_thermal_device intel_rapl_common intel_lpss_pci rfkill intel_lpss int3403_thermal intel_soc_dts_iosf intel_pch_thermal int340x_thermal_zone int3400_thermal acpi_thermal_rel acpi_pad intel_hid sparse_keymap ip_tables dm_crypt hid_logitech_hidpp i915 rtsx_pci_sdmmc mmc_core i2c_algo_bit crct10dif_pclmul drm_kms_helper crc32_pclmul crc32c_intel mxm_wmi nvme drm nvme_core r8169 rtsx_pci serio_raw ghash_clmulni_intel hid_logitech_dj pinctrl_cannonlake wmi video pinctrl_intel fuse
Here is the installed Fedora 31 lsmod (screen doesn’t work)
lsmod | egrep nvidia|nouveau|intel
snd_soc_acpi_intel_match 28672 1 snd_soc_skl
snd_soc_acpi 16384 2 snd_soc_acpi_intel_match,snd_soc_skl
intel_powerclamp 20480 0
nvidia_drm 57344 8
nvidia_modeset 1118208 13 nvidia_drm
intel_rapl_msr 20480 0
kvm_intel 299008 0
snd_hda_intel 57344 6
snd_hda_codec 159744 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek,snd_soc_hdac_hda
kvm 770048 1 kvm_intel
nvidia_uvm 1081344 0
snd_hda_core 102400 8 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_soc_hdac_hda,snd_soc_skl
intel_cstate 20480 0
intel_uncore 147456 0
btintel 28672 1 btusb
bluetooth 626688 41 btrtl,btintel,btbcm,bnep,btusb,rfcomm
snd_pcm 114688 8 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_soc_core,snd_soc_skl,snd_hda_core,snd_pcm_dmaengine
intel_rapl_perf 16384 0
nvidia 20443136 581 nvidia_uvm,nvidia_modeset
snd 98304 24 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm
ipmi_msghandler 73728 2 ipmi_devintf,nvidia
intel_rapl_common 28672 2 intel_rapl_msr,processor_thermal_device
intel_lpss_pci 20480 0
intel_lpss 16384 1 intel_lpss_pci
intel_soc_dts_iosf 20480 1 processor_thermal_device
intel_pch_thermal 16384 0
intel_hid 20480 0
sparse_keymap 16384 1 intel_hid
drm_kms_helper 212992 2 nvidia_drm,i915
crc32c_intel 24576 7
drm 512000 14 drm_kms_helper,nvidia_drm,i915
ghash_clmulni_intel 16384 0
pinctrl_intel 32768 1 pinctrl_cannonlake
