I have Kubuntu 20.04 installed on an older Dell Optiplex 990, I7, 512 SSD, and 16 GB RAM. The installation was screaming for months and has suddenly slowed down considerably. The system monitor program shows little use of RAM but almost 100% CPU on all cores.
I am relatively new to Linux and chose Kubuntu because of the KDE Plasma desktop. I have it running also on Lenovo T440, no problems.
I would like to reinstall Kubuntu or go to OpenSuse version.
I would like to leave my data on the current drive and install the new OS on a new SSD.
baloo_file is 50% of my CPU and 45% of my 16 GB memory.
I have SSDs in my stock. I am asking how to separate the OS from my data by installing a new version of the OS on the new SSD, then getting rid of the OS portion of my larger SSD for data only.
I’m not a KDE user but as I understand the baloo program is an indexer for the files on your system. Once indexed, you’ll have faster results when searching for something on your system. Given that this is its purpose, a fresh install would cause baloo to run wild for a few hours but then once the indexing is done, it should be quiet.
I guess that I need to figure out how to limit baloo to just the specific folder that I need indexed. This has been running for weeks. thanks for your input.
That is the problem with Baloo and @MarkofCain is right. So it is not a bug. Baloo just needs to index all your files and when it is done it will not hog your system anymore.
I would definitely try to limit it and in the worst case even deactivate it. Or on a fresh install I would not even activate it on the first run of the new system.
File indexing on weak hardware or with a lot of data is really tedious.
