Hello everyone,
I’m currently running the latest version of Manjaro Budgie with the latest linux-zen kernel (though I don’t believe my issue is related to the kernel). I have an encrypted SSD for my OS and 5 HDDs which are all encrypted also. Yes, I know that I’m a crazy person. Lastly, I have a jump drive that remains plugged into the same USB port at all times. I have a startup script that I run to decrypt all of my drives and to mount the jump drive, which includes the following lines:
echo "Decrypting encrypted4"
sudo cryptsetup luksOpen /dev/sdd sdd
sudo mount /dev/mapper/sdd /mnt/encrypted4
echo " "
echo "Decrypting encrypted8-1"
sudo cryptsetup luksOpen /dev/sda sda
sudo mount /dev/mapper/sda /mnt/encrypted8-1
echo " "
echo "Decrypting encrypted8-2"
sudo cryptsetup luksOpen /dev/sdb sdb
sudo mount /dev/mapper/sdb /mnt/encrypted8-2
echo " "
echo "Decrypting encrypted4-mirror"
sudo cryptsetup luksOpen /dev/sde sde
sudo mount /dev/mapper/sde /mnt/encrypted4-mirror
echo " "
echo "Decrypting encrypted4-other"
sudo cryptsetup luksOpen /dev/sdg sdg
sudo mount /dev/mapper/sdg /mnt/encrypted4-other
sudo mount /dev/sdf /mnt/backup/
The problem I’m having is that occasionally my HDD at sdg and my jump drive at sdf switch, so it’ll try decrypting my hard drive and error out because suddenly the jump drive is sdg and the hard drive is sdf.
Is there any way to ensure that these drives remain at the same spot and I’m not constantly having to change my script? Thanks in advance!
