I have a Kindle Book I recently obtained.
(Its an IT book thats free for 24 hours as of 2020-01-07, Details for those interested )
And I am trying to find how I can take the book from Amazon’s ecosystem to my local Epub readers. I have not done this before so I am unfamiliar on how to do this on Linux.
Does Calibre not do that? I have maybe 2 Kindle books so I haven’t ran into this a ton, but I also read off a Kindle.
Roundabout way, could you put it onto a Kindle, then back it up into Calibre, convert it, then move it to your local epud reader?
Also, doesn’t Amazon give you the option to download the ebook file from your Amazon account? IT’s been a long time since I’ve worked with that, but I ran into a similar frustration trying to pull my Amazon-purchased-digital-movie from their ecosystem and ended up empty handed as well.
So I didn’t think Amazon would let you download it directly to your filesystem.
I thought they only let you send to a Kindle device or the Kindle for PC Windows/macOS app.
However I just checked and there is an option to “Download and transfer via USB”. So maybe it possible to then just import the file into Calibre. If you can get that far, you probably still would need to strip the DRM. Perhaps this would work: Exactly how to remove DRM · apprenticeharper/DeDRM_tools Wiki · GitHub
