Community Member Ryan Walter made an awesome video awhile ago on this process and I decided to use what I’ve learned about git to create a print version that goes along with the video. Between the print version and the video, you can have a website up and running for 2021 in no time!! The actual webpage that I created can be found here but I will include all the information as well below so you don’t have to visit the link if you don’t want to. DISCLAIMER: images and shortcodes won’t load below because I literally just copied the markdown and didn’t adjust the urls. So if you want to see the finished product in it’s entirety, you’ll need to visit the page.
Ryan Walter from the DLN community has a great video on front page linux that shows how GitLab can be used to host a static website. I thought that since DLN is doing a weekly tip on git, it would be a great time to try and show case that and create companion documentation for Ryan’s video.
GitLab does have its own documentation but I hit several snags when trying to follow it while Ryan’s worked seamlessly.
This guide is going to assume that:
- You have a GitLab account
- SSH Keys are used between origin and master
git
is installed on your host computer - Basic git commands are understood so that explanations for every command are not needed.
- The ability to install the package
hugo
on your host machine for testing purposes.
If these assumptions are correct, then the difficulty of this tutorial is estimated to be 2 out of 10. If you don’t have the required knowledge for these assumptions, check out my previous walkthough that follows the DLN tip of the week for git. Ryan uses Fedora for package installation and my guide will be using Ubuntu so there may be slight contradictions between his video and the guide.
Setup
I will be using the same file hierarchy as my previous guides but will be creating a new folder called hugo
. The packages for hugo will be installed and git will be initialized for this repository.
/home/rastacalavera/git
mkdir hugo
cd hugo
sudo apt install hugo -y
hugo new site ./
git init
git add *
git commit -m "first commit
The next set of commands will download the Beautiful Hugo theme and allow you to preview it locally in your web browser.
cd themes
git submodule add https://github.com/halogenica/beautifulhugo.git beautifulhugo
cd ..
cp -r themes/beautifulhugo/exampleSite/* ./
hugo serve
Now you can see the website in your browser by going to http://localhost:1313/
Close down the server using CTRL+c, commit your changes and push the project to GitLab:
git add *
git commit -m "working website"
git push -u git@gitlab.com:YOURACCOUNTNAME/hugo.git master
Front End Changes
Now we’ll step away from the commandline for a bit and work in the browser on GitLab.
We want GitLab to update our changes automatically so we need to setup the CI/CD file so that our container will be rebuilt with each push.
Now, the settings of your page need to be set to public.
Finally, we can see the site url and visit the page
The website looks a little broken, that’s okay though, we are going to fix it!
Back to the commandline
Time to return to our commandline prompt in our hugo folder. First we are going to pull down all of our front end changes.
git pull
Now we edit our config.toml
file:
nano config.toml
In the first line, you need to put your GitLab url of your website between the" "
so for instance mine looks like this:
baseurl = "https://rastacalavera.gitlab.io/hugo2/"
Now, push up the changes:
git add *
git commit -m "new url"
git push
You can watch as your job is run by git hub
When it is complete and you refresh the website page, it should look like the one you previewed on your main machine.
All of the actual page content is available in the post folder:
git/hugo/content/post
At ~23 minutes, Ryan deletes all the local files using
rm *
in the post directory. This doesn’t actually delete them from the main repo and those pages will still be present on the home page. To delete them completely git rm *
must be used.
Now you can create your own markdown file for the website with the yaml header included.
title: My First Post
subtitle: learning Hugo
date: 2020-12-22
#publishdate:
#draft:false
#expiredate:
#author:
# this is where you can experiment with markdown
When done, add your files and push them up.
git add *
git commit -m "remove template and add original content"
git push
Once the job is complete on GitLab, then you’ll need to refresh your changes and everything should look different.
Side note
If you want to add images into your website, the easiest way to get started is to place them all into the static
folder.
Once your images are in there, you can reference them using markdown like so:
Notice that the static
folder is not in the path and the end of your public URL is there. It took me hours to troubleshoot this so hopefully this saves other people a step.
{{< youtube -q6ZiCroiGM >}}
