I have a nest that I need to be able to access through nest website until I get a better non google camera. I can access video feed through every other browser I have tried(Web,Chrome,etc) I would like to stay with one browser only Firefox but nest is making that difficult for me. Any help will be appreciated.
Reason
I am newer to the show started listening at end of last year. I am currently in the process of degooglefying my life. I live in Tennessee and nest camera is on my lake property in Alabama so it will be the last piece of google to be replaced. Which means I still need to use the nest till after winter.
The way nest works is you login to nest home on nest.com after that it loads you into your dashboard to select which camera feed you want to load dashboard where you select never loads just stays on the blue screen. Not sure how much that helps but give me a little bit and Ill see if I can pull a error log when loading it.
Perhaps Firefox is blocking the video / audio? The newer versions do this by default. Their is a little graphic next to the lock icon in the address bar, click on that and then allow video from the Permissions selection. Hope that might work.
