To start I believe that Fedora is the flagship Linux desktop experience.
Now I love using arch and being able to say I use arch as much as the next guy on here and I have a lot of respect and praise for PopOS and System76, but the best experience for me on Linux has been Fedora and it only seems to get better and better with each new release. It seems to me like they are really ahead of the curb with things like Pipewire, Wayland, BTRFS, and Flatpaks. All of that among other things that make it the most solid Linux desktop experience, now that is to say It can and is improving and I just wanted a place to vent a little about the things I really want to see in Fedora in future releases some of which is already being implemented.
Built in Dark mode
Accent colors
Optional system tray icons and the ability to hide them in a sub menu built in
Optional panel mode or classic mode built in for those people I cannot convince to use gnome the gnome way.
Free sync / variable refresh rate
BTRFS snapshot management from settings app or GUI
Fully functional fractional scaling in wayland
nautilus context menu option to enable opening folders in nautilus as root without the need of the terminal
uninstall option in context menu when you right click on application in the show applications view
accessibility support for remaping midi, gamepad or other controllers for use in games or to control the desktop
Option in installer for enabling the full flathub store
prompts for flatpak permisions for apps and a way to manage said permissions in a integrated way maybe in settings app
basic appimage integration in gnome built in
Michael AI BOT integration option for accessibility voice support and home automation integration with home assistant
I think I will leave it at that for now, thanks for reading my post.
