Originally published at: https://frontpagelinux.com/tutorials/easily-install-jack-audio-with-ubuntu-studio-installer/
Ubuntu Studio leader here. Great tutorial! I’ve linked to it on the Ubuntu Studio Installer page Another thing that can be done is PulseAudio can be totally disabled or bypassed while using OBS’s built-in Jack clients.
Hello, thank you so much for your kind words. I really appreciate that.
Ubuntu Studio is amazing. Not only it is a great distribution, but you guys even make it super easy to install all the Ubuntu Studio tech in any Ubuntu Flavor. How awesome is that?
Thanks for your great work!
Hello! I just read through the tutorial and I’m trying to get my audio setup with JACK working on Ubuntu 20.04. I installed Ubunto Studio controls and the program launches perfectly, no issues there. I’m just confused on how to best choose the Jack Master Device and USB devices. Here is my setup:
The options available in the Jack Master Device show the following:
defaultUSB Jack MasterPCH,0,0 playback and capture (ALC289 Analog)PCH,X,0 playback (HDMI X)).For the USB device that should be Master option, choices include:
No USB Master, USB 0,0 playback and capture (USB audio)
Dock,0,0 playback and capture (USB audio)Dock,1,0 playback and capture (USB audio)Headset,0,0, playback and capture (USB audio)I’m still really new to JACK, but is there any guidance or tutorials on how to map multiple USB-connect devices together like in my setup?
Hello,
If you have multiple devices to connect to jack you can do so without issues:
Please note if something is not working right away after adding devices to jack, do not panic. ![]()
Close Carla, stop Jack, and restart Jack. If that is not enough, you can try and reboot your pc.
I hope this helps.
Cheers,
Mauro
Hey, first post here after following the great article and the comments.
After following the guide on Ubuntu Mate 20.04, I have a minor but quite annoying problem:
After each reboot, all output channels (Master, Speaker, Headphones) are muted. ![]()
To hear sounds again, I have to open QASMixer via Ubuntu Studio Controls and pull the channels up again.
I have to use the “Open QAS Mixer” in Ubuntu Studio Controls → Audio Setup. If I open QASMixer from the Menu only see limited controls: Two channels for Master Out and In
(Sorry, can just post one Screenshot)
Is there a way to preserve Mixer Settings across a reboot, by changing a configuration value somewhere? ![]()
Greetings from germany,
Markus aka Krok
Hi,
I also noticed something similar, and found an open bug. I added my input, feel free to also have a look and report there.
Hi,
This is no solution yet but my personal workaround:
I’ve written a simple script to push the affected levels to 11… I mean 100%.
At the moment I doubleclick this after logging in, but I plan to let systemd run it for me later on
#! /bin/sh
amixer -c 1 sset 'PCM' 100%
amixer -c 1 sset 'Master' 100%
amixer -c 1 sset 'Speaker' 100%
This tells ALSA (which seems to be at the root of my problem) to set the relevant output values of (in my case) sound card 1 to 100%.
If someone else wants to use this, get the correct number of your sound card with
cat /proc/asound/cards
your sound card controls may have different labels than mine. Use
amixer -c 1 scontrols
with the correct number for your sound card after the -c
HTH, Markus
Hello,
Thanks for sharing. Could you also post it in the bug report i shared. More people involved there will definitely draw more attention to the issue. I believe we should ask to assign the bug to ALSA, as the issue is not QASMixer.
press F6 to show device selection options on right side
to save mixer settings to be restored on reboot:
sudo alsactl store
Thank you very much Mauro Gaspari, for the first time, I was able to install and configure Ubuntu studio (audio). I am excited to explore and discover the tools that interest me in this area. Good job, with your explanations I managed to do everything at first (I’m not an expert). Thanks again for your help.
Thanks for your article. I’ve configured Studio Control on my user and it’s works fine.
There is some problem with the other user of the system after close session. Pulseaudio doesn’t detect the audio interface and no sound. If I reboot the system and log in with that user, works fine.
I suspect it has to do with the jack session that the other user opened. Maybe the jack server is not stop when the session is closed…
That user is for my wife and she doesn’t need Jack. But it’s a shame that I have to reboot the computer to use that user.
My base system is Kubuntu 20.10.
Do you have any ideas on how to solve it?
Thanks
Hello,
I am aware that JACK might have some issue when logging in and out of the system. That might be an issue for multi user systems unless you reboot instead of relog.
Having said that, studio-controls and autojack settings are per user, so you can leave studio-controls settings as default for the user that does not need JACK plugins. And you can setup a small login login script to send the “autojack” command so that JACK is forced to stop and restart, therefore solving your problem.
I hope this helps. If this is not enough, you can join matrix room for support, or leave a question in ask ubuntu. Support – Ubuntu Studio
Thank you for your response.
I posted an issue on Studio Controls’ GitHub repository and this is what I got back: No sound with other user after close session · Issue #42 · ovenwerks/studio-controls · GitHub
It seems that the problem is not the application, but the desktop environment.
I’ll see if the solution they propose works for me.
Greetings.
This is really exciting stuff! I learned about JACK from this tutorial and I’ve been able to use JACK with the Ardour program. Thanks for writing the article.
It took a lot experimentation but I got it working with a guitar connected to a preamp connected to the microphone input and a USB headset. I’m leaving the configuration here in case anyone else has this specific case of non-USB input but USB output.
In the end, the settings were
Jack Master Settings
Jack Master Device PCH,0,0 (ALC293 Analog)
USB devide that should be Master: No USB Master
Extra Devices (here is where the USB headset comes into the picture)
] Bridge USB Devices to Jack When Plugged In
Headphone plug in Action and Device Switch outputs to Headphones | Controller,1,0
Main Output Ports Controller,1,0-out:playback_1
Pulse Bridging (for the in and out endpoints : the microphone in and the headset out)
Added an input bridge set to system:capture_1
Added an output bridge to Conroller,1,0-out:playback-1
Also have
] Bridge ALSA to Jack MIDI
