One thing I’m using with Snaps is having the ability to install beta or edge version of applications.
Does Flatpak have that ability?
I believe flatpak calls this “branches.” If I search for an app by using the “Applicaion ID,” flatpak offers me the option of installing a beta:
flatpak install org.freecadweb.FreeCAD
Looking for matches…
Remotes found with refs similar to ‘org.freecadweb.FreeCAD’:
1) ‘flathub’ (system)
2) ‘flathub’ (user)
3) ‘flathub-beta’ (user)
Which do you want to use (0 to abort)? [0-3]:
After install, either of the following commands will run the stable branch: (stable is the default when no branch is declared)
flatpak run org.frecadweb.FreeCAD
flatpak run --branch=stable org.freecadweb.FreeCAD
But the following command will run the beta version:
flatpak run --branch=beta org.freecadweb.FreeCAD
When I looked up Firefox:
$ flatpak install firefox
Similar refs found for ‘firefox’ in remote ‘flathub’ (system):
1) app/org.mozilla.firefox.BaseApp/x86_64/20.08
2) app/org.mozilla.firefox.BaseApp/x86_64/21.08
3) app/org.mozilla.firefox/x86_64/stable
4) app/org.mozilla.firefox.BaseApp/x86_64/22.08
Which do you want to use (0 to abort)? [0-4]:
I don’t see a way to install ESR, and I’m not sure what the difference is between those 4
Ah, yes. I can see why you’re confused. I’m not sure there is an ESR available as a flatpak, but let’s see if we can clear up part of this.
Let’s see if the search command clarifies things for us: (I deleted some fuzzy matches, but these two options were at the top of the list)
flatpak search firefox
Name Description Application ID Version Branch Remotes
Firefox Fast, Private & Safe Web Browser org.mozilla.firefox 112.0b9 beta flathub-beta
Firefox Fast, Private & Safe Web Browser org.mozilla.firefox 111.0.1 stable flathub,flathub-beta
If I then want to install the beta 112.0b9 branch, I note that it resides on the flathub-beta repository as indicated in the “Remotes” column. So I run the following command: (Note that I specify the remote repository “flathub-beta” after the “install” command)
flatpak install flathub-beta org.mozilla.firefox
Similar refs found for ‘org.mozilla.firefox’ in remote ‘flathub-beta’ (user):
1) app/org.mozilla.firefox/x86_64/beta
2) app/org.mozilla.firefox/x86_64/stable
Which do you want to use (0 to abort)? [0-2]:
Since the flathub-beta repository houses both a stable version and a beta, I’m presented with the option to choose my target install.
