At home, I use Firefox, Ghostery (testing it) & Brave (if I need Chromium). In my workplace, I use Firefox (mainly) & Edge (company standard & I have to use Windows (ugh)). I’m trying to find a good, trustworthy open source cross-browser syncing extension that I can host in OneDrive (work) or Nextcloud (home). Any suggestions? Also, I’d prefer if that tool won’t require me to have an offline copy for it to work.
I remember in a DLN episode they talked about some cross-browser bookmark extensions, but I can’t remember which one it was.
xbrowsersync is what I use. It works with all the browsers and instead of a username when you first set it up it gives you an anonymous sync id, and then you set up a password for it, and then you are good to go. It doesn’t even ask for any info from you at all. It plus bitwarden are the first 2 extensions I install on any browser. Now if there was something that was cross browser to sync tabs and history I would be set.
I may have to play with it on a browser by its self. Last time I messed with floccus it did some weird stuff to my bookmarks and I had to spend hours reorganizing them.
