Auto resizing Xfce and MATE resolution in Spice (VM guide)
Unlike Plasma, Cinnamon, Gnome, LXDE and LXQt DEs… our beloved Xfce and MATE don’t auto-resize with the qemu-guest-agent library.
Not for long…
Open the VM window and make sure View > Scale Display > Auto resize VM with window is checked.
Start the guest VM and install spice-vdagent
sudo dnf install spice-vdagent # Fedora/CentOS/RHEL
sudo apt install spice-vdagent # Debian/Ubuntu
Restart the guest for changes to take effect (re-login alone won’t do it)
Manual resize:
Run the following command in terminal to resize once:
# Terminal:
xrandr --output "$(xrandr | awk '/ connected/{print $1; exit; }')" --auto
Command spread out:
# Get the name of the first connected display from xrandr using awk
DISPLAY_NAME=$(xrandr | awk '/ connected/{print $1; exit; }')
# Tell xrandr to refresh the display so it uses the new resolution applied by qemu-guest-agent
xrandr --output "$DISPLAY_NAME" --auto
To map this to a key you’ll want to use the following command and you’ll sometimes need to hit it 2 or 3 times in a row due to update lag.
# Shortcut command:
/bin/sh -c "xrandr --output $(xrandr | awk '/ connected/{print $1; exit; }') --auto"
Automatic resize:
There might be a way to watch a particular file so it only triggers on qemu-guest-agent resize but a loop gets the job done in the meantime.
sudo touch /usr/bin/auto_resize
sudo chmod +x /usr/bin/auto_resize
sudo nano /usr/bin/auto_resize
# Paste the following:
#!/bin/bash
while true
do
DISPLAY_RES=$(xrandr | grep +)
if [ "$DISPLAY_RES" != "$DISPLAY_RES_LAST" ]; then
for i in {1..4}; do
sleep 0.3
done
fi
DISPLAY_RES_LAST=$DISPLAY_RES
sleep 1
done
# Test the script is working:
auto_resize
# Hit Ctrl+C to quit
# Paste the following to your preferred startup location:
nohup auto_resize > /dev/null 2>&1 &
# Xfce GUI example:
# App Menu > Session & Startup > "Application Autostart" tab
# Click "Add"
# "Name" field, paste:
auto_resize
# "Command" field, paste:
# Click "OK"
# Log out and back in
