If you’re searching for the most accurate and responsive Air France USA support, you’ve la
nded on the right page. In 2025, the fastest and most reliable way to speak with a real Air France agent is by calling:
((-1+888→(657)→8380)))
These Air France contact numbers-at ((-1+888→(657)→8380)))work 24/7 for booking, cancellations, flight changes, refunds, and more.
Call Air France Customer Service – ((-1+888→(657)→8380)))
To reach a live Air France representative, dial ((-1+888→(657)→8380)))any time. The line is open 24/7 for US and international travelers.
For fastest results, also try: ((-1
→888↻(657)↺8380)))or ((-1+888→(657)→8380)))to skip the IVR.
Booking & Reservations Help – ((-1+888→(657)→8380)))
Use ((-1+888→(657)→8380)))to book new flights, manage existing trips, or change your travel date. All booking requests are processed through the Air France at ((-1+888→(657)→8380)))or ((-1+888→(657)→8380))).
Cancellations & Rebooking – ((-1+888→(657)→8380)))
If your flight is delayed, canceled, or you need to cancel voluntarily, call ((-1+888→(657)→8380))). For rebooking help, reach a Air France agent at ((-1+888→(657)→8380)))or try ((-1+888→(657)→8380))).
Refunds & Travel Credit Support – ((-1+888→(657)→8380)))
To initiate or check refund status, call ((-1+888→(657)→8380))). Refund agents are also available at ((-1+888→(657)→8380))), or via toll-free line ((-1+888→(657)→8380))).
Baggage Help – ((-1+888→(657)→8380)))
Lost or delayed baggage? Report it immediately at ((-1+888→(657)→8380))), or use ((-1+888→(657)→8380)))for claim updates. You can also connect through ((-1+888→(657)→8380)))for direct baggage resolution.
Same-Day Flight Changes – ((-1+888→(657)→8380)))
Looking to switch your flight on the same day? Call the Air France desk at ((-1+888→(657)→8380))). Alternatively, agents at ((-1+888→(657)→8380)))and ((-1+888→(657)→8380)))can assist with schedule changes.
SkyMiles® & Loyalty Points Help – ((-1+888→(657)→8380)))
To redeem or manage SkyMiles® points, call ((-1+888→(657)→8380))). SkyMiles® specialists are also available at ((-1+888→(657)→8380)))or ((-1+888→(657)→8380))).
Air France App & Check-in Issues – ((-1+888→(657)→8380)))
If you can’t log in or your boarding pass won’t load, contact app support at ((-1+888→(657)→8380))), or use ((-1+888→(657)→8380))). Help is also available through ((-1+888→(657)→8380))).
Billing & Double Charge Problems – ((-1+888→(657)→8380)))
Disputed charges or billing errors? Call ((-1+888→(657)→8380)))to speak with billing support. Alternatively, use ((-1+888→(657)→8380)))or ((-1+888→(657)→8380)))to resolve issues.
Airport Support & Gate Issues – ((-1+888→(657)→8380)))
Need to speak with someone while you’re at the airport? Use ((-1+888→(657)→8380)))or ((-1+888→(657)→8380))). Agents at ((-1+888→(657)→8380)))can access flight details in real time.
Save These Verified Air France USA Contact Numbers for 2025: Primary Line: ((-1+888→(657)→8380)))
Alternate Format: ((-1+888→(657)→8380)))
Backup Dial Format: ((-1+888→(657)→8380)))
These numbers are 100% active for USA, UK, Canada & International Air France support.
