I’m setting up a new desktop computer, and I thought I would experiment a bit. Normally, I have been running Linux on old laptops with just one SSD. However, in this new desktop, I have three drive bays in the case. I would like to have the following:
- Bay #1 = SSD (120GB with /boot and /root for sure to use the speed of SSD for fast boot up and execution of programs) connected to SATA 6 port on motherboard formatted with EXT4.
- Bay #2 = HDD (1TB Western Digital Black) connected to SATA 6 port on motherboard formatted with Btrfs.
- Bay #3 = HDD (1TB Western Digital Blue) connected to SATA 3 port on motherboard formatted with Btrfs.
This is making use of hardware that I have on hand. I could change the 1TB Western Digital Black to a Blue because I have two of those on hand. The motherboard has 2 SATA 6 ports and 4 SATA 3 ports. I would like to set up the two HDD’s in a RAID 1 (I think this is right to get mirrored drives for a total storage space of 1TB).
My first thought was to move my whole HOME folder to the RAID 1 drives. However, that would move my configuration files over to the RAID 1 drives too, which may or may not slow down the speed at which my programs open. So, one suggestion I got is is move just some of the HOME directories over to the RAID 1 drives like Pictures, Videos, Music, and Documents because those have all of my important data files, but I don’t access most of those files on a daily or even weekly basis. Most of those files are used a few times a month or are there backed up from completed projects that I have done in the past. Those folders normally get synced with syncthing between 4 computers in 2 different locations, and once a week those files get rsynced to an external drive attached to our home server. (I probably need to add a cloud backup for those files too, but that is another topic.)
So what would you do?
- Move the whole HOME folder from the SSD onto the RAID 1 HDD’s.
- Keep all folders on the SSD, and just symlink a few of the key HOME folders to the RAID 1 array so that those larger data files are kept there.
- Do something else with fstab or some other method to move all of the data files onto the RAID drives.
- Throw out all of the above plans because there is something better that involves Btrfs on all the drives. (The main reason I have EXT4 on the SSD is because I just did a standard install of MX Linux on that drive to have a working Linux install.)
Thanks for the advice.
