Hi there,
I have been trying to use gnome on / off for a while now, it was the first desktop I got when I left windows and started distro hopping, because of win10 19.03, yeap, that was my last stop for me.
Anyway, I always found the behaviour of the automatic airplane-mode very, very annoying, it is the only desktop that does that, and I cannot understand why.
So, for the ones who do not know; when you turn wifi off, it automaticaly turns airplane-mode on, and then, when turning arplane-mode off again, wifi AND bt get on, and then you have to turn bt off again if you don’t want it. Only to repeat the ordeal every time you want to toggle the wifi or the bt, and again, when the system boots.
I still have no idea how to ‘fix’ this issue, that is the reason I am posting this, does anyone know how to do it?, but also, I am trying to understand the logic behind it.
I do not mean to hurt anyone’s feelings, but now I understand that this is not a bug, it would have been fixed by now, this is how it is supposed to work. and I just can’t bend my brain arround it.
Thank you and again, this is not a hate post, I really need to ask.
Cheers
Edit: BTW, I’m on Endeavour OS, in case someone knows a fix.
