437 /cte /cbd
This is from 1998
Lots of research shows hemp and even thc from cannabis is a neuro-protectant and thc-a, the raw unheated version will not give any euphoria but may also be beneficial in the same way.
Hrmp helps a lot of different ailments from seizures, autism, asthma, and stroke and brain injuries.
Hemp is without exception, allowed in all 50 states and so there, in theory, should be ZERO hesistation nor hinderance in both aquiring quality organic plant, and helping transport and provide it. Please research this and act quickly.
A helmet is not very padded, maybe half a foot or less of plastic foam, so there may be a high amount of injury. Our bodies (all mammals and some others) produce endogenous cannabinoids and more in times of need. Our bodies are designed to receive these plant molecules and there should be no stigma against this fact.
There are many companies with websites offering hemp flower and extracted oil. I recommend just the plant material as less processing leaves more molecules intact.
Stay away from the 8 stuff, all synthetic
Major brain injury will, not can, WILL cause depression, and is well recognized as an effect. Oliver Anthony had a fall at work and was down for at least half a ywar or more, talks about it on the JRE
Hemp is actually quite affordable especially if you buy shake, the loose leaf from buds, not only is it much cheaper, basically just as effective but also allows easier edibles
