I have a System76 Lemur 6 issue. It is not a daily driver. It’s used as a travel or backup computer. For about the last six months the laptop has been just randomly shutting down as if it has lost power. Last week I installed Pop!_OS on it and updated it to 19.10. The after the reboot updated the firmware from settings. I hoped the firmware update would fix the problem but no luck. The shutdowns happen randomly and don’t appear related to whether the laptop is being moved or just running on the table.
I could be a heat issue. When I removed the bottom the heat-sink and fan appeared firmly seated and there wasn’t any give so the thermal paste is somewhat intact. What is the best method to keep track of the cpu temp?
It’s not temp. The laptop just lost power with temp at 46C. I though I’d pick it up and test if moving it did anything and it cut off. Is there something that could be compressed on the front left of the laptop (bottom left of this pic) that could cause this?
