I´ve come across an errormessage when trying to compile the linuxkernel, that I haven´t seen before and can´t find an answer to. It seems to somehow be tied to 20.04 specifically because I get it on other 20.04 installs, but not where I have earlier versions of *buntu running. The error shows in the last step when doing the actuall compoilation of the code, wich is:
make -j getconf _NPROCESSORS_ONLN deb-pkg LOCALVERSION=
I´ll post a screenshoot of the errormessage. The language is swedish but most of the text is in english.Where it says “Fel 2” is translated to english as “Error 2”.
I´m not asking to be served the answer on a silverplatter (unless you want to, ofcourse ). But if you could point me in a direction where I can find the answer, I would most appreciative.
Are you not running the stock kernel? I am wondering what steps you took to get to this point. I haven’t compiled a custom kernel for some time and never on Ubuntu.
But I found my problem. I turned out to me failing hardware that generated weird and inconsequential errors. I recently upgraded all components in my rigg and didn´t think of that as a sources of problems, initially.
