Nautilus sorting bug
Hi,
is there a know fix for the bug that Nautilus sorts case sensitive like LOW letters after sorting alphabetically? Its Gnome 3.38 under Manjaro, but it seems like this would be a bug that has come and gone in the past 10 years :unamused:
Like this:
There’s a ā€œsolutionā€ to this problem found here:
https://bbs.archlinux.org/viewtopic.php?id=34699
Or here:
Quote: " To get the sorting like you described, add the following line to ~/.gnomerc (create if it doesn’t exist and mark it executable): export LC_COLLATE=POSIX . One downside is that capital letters will sort ahead of lower case letters."
I don’t know if there’s a global fix. I haven’t ran into this problem yet, so i couldn’t say.
Hopefully these links will help somewhat.
