I’ve been running out of space on one of my partitions and I found out that one of my snap applications I don’t even use takes 11GB of space. Let’s remove it.
I run snap list
to see how to use it – there’s remove – great, let’s run it.
sudo snap remove brave
and I get the message
save data of snap "brave" in automatic snapshot set
which takes long while and fails, likely because I don’t have space to save the thing and application doesn’t seem to let remove package without it.
Search for solution on the internet doesn’t help as “snap” returns results mostly for “snapchat” and when I force it to skip entries with “snapchat” and try looking for problem with snapshot, of course I get results about screencap taking software.
So it looks like with Snap, I can’t free myself some space, because I don’t have enough space. Either that or removing packages just doesn’t work.
