You know that map is searchable with Crtl + F right? Frikkin’ live by it.
Destination Linux, ha, so long as it had plank I’m in.
I would go for a DLN distro that had a custom Layout Manager. The user could switch between the following layout/theme combos:
Rocco - pixel perfect… (just like Pop_os.)
Ryan - still looks like pop_os
Noah - default kde and backs itself up every 30 seconds
Michael - looks like HML or Mint (as you already figured)
Jill - it’s all… pink n’ penguinny?
Zeb - Ascii widgets, of course.
The DLN Distro has to be based on Bedrock Linux. Not only three different package managers but also 3 different distros automatically included in the default installation.
The path to commands which are common across all three distros is decided by random each time it is called.
you should patent the “PUN” package manager
A Arch based Distro like Arco Linux with the Calamares installer with DLN suggested apps.
I it was a sight!
An Arch installer minus Pacman,
All further packages must be added using Linux from Scratch method.
I have to agree with some of these posters… the Brown and Orange color scheme was pretty cool.
