Not strictly a Linux question but I do need a solution that runs on Kubuntu 19.10.
I want to make backups of my dvds. The one test dvd made a mkv file using MakeMKV. Of course it’s a large file. I’m trying to reduce the video down to an acceptable size using Handbrake and changing it to mp4. The problem is that the format is not playable on my Samsung tv and somehow the latest update bricked my Nvidia Shield.
How can the format be changed from mkv to mp4 while reducing the size? I’d rather not take more than two steps at the most. And I don’t see how to change the file format in Handbrake. What are my options?
If you are comfortable with the command line, using ffmpeg may be what you’re looking for. You should be able to reduce the file’s size by doing this, after substituting the file’s name where applicable. I suggest making a backup of the file to be safe.
Is it necessary to keep it in the mkv format? After a quick skim of this, I think you may need to convert it to a different format in order to play it on your (smart?) tv.
I may end up adding a step by using ffmpeg to change the container to mp4 then use handbrake to reduce the size. No worries. Something to play around with. Thanks
you can replace libx264 with any codec ffmpeg supports that your tv can read. h264 (the one I indicated in the command above) should work pretty much everywhere.
I’m a fan of WinFF myself. I’m not suggesting the OP was by a noob, but here is what I would say to a noob:
In the “Output Details” tab, under “Convert to:” I choose “MPEG-4”, then under “Preset:”, I choose “MPEG-4 720p”. I also choose a different Output Folder.
When you click the “Options” button, more tabs get revealed. In the “Video” tab, I specify a smaller “Video Size”, like 640x360, then in the “Audio” tab, I set “Audio Bitrate” to 80, and “Audio Channels” to 1. Then I click the “Convert” button at the top.
These directions even work on a video shot in portrait mode with my phone! And I didn’t have to specify anything to do with orientation or rotation.
This shrunk a 1 minute 1080p video of 143MB, down to 23MB. Suitable from serving from a Nextcloud share, suitable for streaming even over a modest cellular data connection.
