After running ddrescue
on my drive for who-knows-how-many days, I decided to cancel it. This was the output just before I cancelled:
ipos: 12096 MB, non-trimmed: 4020 MB, current rate: 0 B/s
opos: 12096 MB, non-scraped: 0 B, average rate: 2498 kB/s
non-tried: 242716 MB, bad-sector: 0 B, error rate: 0 B/s
rescued: 753432 MB, bad areas: 0, run time: 3d 11h 45m
pct rescued: 75.33%, read errors: 62266, remaining time: n/a
time since last successful read: 2d 7h 10m
Copying non-tried blocks... Pass 5 (forwards)^C
After I ran mount
, I got this:
$ sudo mount -t ntfs WDPassport-parents.img /mnt
ntfs_mst_post_read_fixup_warn: magic: 0x00000000 size: 1024 usa_ofs: 0 usa_count: 0: Invalid argument
Record 0 has no FILE magic (0x0)
Failed to load $MFT: Input/output error
Failed to mount '/dev/loop63': Input/output error
NTFS is either inconsistent, or there is a hardware fault, or it's a
SoftRAID/FakeRAID hardware. In the first case run chkdsk /f on Windows
then reboot into Windows twice. The usage of the /f parameter is very
important! If the device is a SoftRAID/FakeRAID then first activate
it and mount a different device under the /dev/mapper/ directory, (e.g.
/dev/mapper/nvidia_eahaabcc1). Please see the 'dmraid' documentation
for more details.
Output from fdisk
$ fdisk -l WDPassport-parents.img
Disk WDPassport-parents.img: 931.5 GiB, 1000169537536 bytes, 1953456128 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x69205244
Device Boot Start End Sectors Size Id Type
WDPassport-parents.img1 218129509 1920119918 1701990410 811.6G 72 unknown
WDPassport-parents.img2 729050177 1273024900 543974724 259.4G 74 unknown
WDPassport-parents.img3 168653938 168653938 0 0B 65 Novell Netware 386
WDPassport-parents.img4 2692939776 2692991410 51635 25.2M 0 Empty
and with parted
GNU Parted 3.2
Using /home/WDB4T/yamiyukisenpai/BACKUP/WDPassport-parents.img
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) print
Model: (file)
Disk /home/WDB4T/yamiyukisenpai/BACKUP/WDPassport-parents.img: 1000GB
Sector size (logical/physical): 512B/512B
Partition Table: loop
Disk Flags:
Number Start End Size File system Flags
1 0.00B 1000GB 1000GB ntfs
I already tried running Windows’ chkdisk
on the drive months ago. Won’t work at all.
When I tried with kpartx
$ sudo kpartx -av WDPassport-parents.img
add map loop63p1 (253:0): 0 1701990410 linear 7:63 218129509
add map loop63p2 (253:1): 0 543974724 linear 7:63 729050177
device-mapper: reload ioctl on loop63p4 failed: Invalid argument
create/reload failed on loop63p4
