this seems like a joke but probably would be a good way to present it lol
I thinks you should make it easy to move more Apps and professional Apps to Linux!
So probably you should invent a general Linux App package format, that allows you to containerize the App, avoid dependency hell, check for updates say 4 times/day, only sends the changed part during an update, rollback a failed update and enable/disable automatic updating. And in the end you should give the format a snapping name
Oh, I forgot, don’t have partly filled, outdated repositories everywhere on the Internet! Don’t allow criminals to set up a repository with corrupted Linux software. Avoid long searches for the right repository, so provide one safe, up-to-date repository.
